Simple EPP IO board
19 Mar 2010 13:08 - 19 Mar 2010 16:51 #2370
by eslavko
Simple EPP IO board was created by eslavko
Hello...
As my machine happily run under EMC and parport driver now I'm runing out of pins.
Currently I have 3x3 pins to control 3 steppers (custom design with strange 3 wire interface) based on linisteper. Work perfect in halfstep/full torq with my 3V 3A steppers. It has power save function too (after 1 sec no moving the current is halved). Next I have spindle output relay with chargepump and chargepump enable all signal. Few limit and home switches and there are no free pins left. .. and as I use laptop there is no way to add another lpt. And of course all things is opticaly isolated from pc.
So as I want to extend this to one more motors (like to have two bipod for foam cutter) I'm in stage of designing board. For now I'm planed.
4 relays 10A/240V AC (all 4 operates as chargepump so false triger is not likely)
20 Digital outputs can be extended (up to 72 is possible but that's owerkill for software stepgen)
16 Digital input's can be extended (up to 80 but that's too is overkill for software stepgen)
EPP interface side opticaly isolated from other components. (20 cheap optocoupler's needed instead at least 32 if output side is isolated)
Material cost should be under 25Euro.
Software interface very simple and fast. As I study driver the IO is done in one place and all bits is output at one sub.
So my plan is to
EPP WRITE ADDRES as byte 0 (relays
EPP WRITE DATA as byte 1 (1'st 8 lines)
EPP WRITE DATA as byte 2 (2'nd 8 lines)
EPP WRITE DATA as byte 2 (3'rd 8 lines)
.. .. .. up to 9 writes (total 10 bytes)
and for read similar
EPP READ ADDRES (read 1'st 8 lines)
EPP READ DATA (read 2'nd 8 lines)
EPP READ DATA (read 3'rd 8 lines)
... ... up to 10 bytes possible
Very simple and low overhead.
The board has only digital logic. No PLD's No CPU's Just Optocouplers 74HC4017, 74HC00, 74HC14,74HC573 and few discrete components.
Someone interested?
Slavko.
p.s.
I don't want to sell. When done all design will be posted on forum for free.
So my plan is to
Someone interested?
Slavko.
p.s.
Last edit: 19 Mar 2010 16:51 by eslavko.
19 Mar 2010 16:44 #2373
by eslavko
Replied by eslavko on topic Re:Simple EPP IO board
Schematics - pre - alpha
20 Mar 2010 11:26 #2386
by BigJohnT
Replied by BigJohnT on topic Re:Simple EPP IO board
Nice schematic, I'm not an electronic guy but lots of folks are short of I/O and make compromises on their machines. I could use a few more I/O on my lathe.
Thanks for sharing
Thanks for sharing
24 Mar 2010 18:52 #2431
by eslavko
26 Mar 2010 10:49 #2449
by eslavko
26 Mar 2010 10:50 #2450
by eslavko
26 Mar 2010 10:51 #2451
by eslavko
26 Mar 2010 11:17 #2452
by BigJohnT
Cool. How did you etch the board?
26 Mar 2010 11:54 #2453
by eslavko
BigJohnT wrote:
Just google for toner transfer method for making PCB.
I simple therm....
I print image with laser printer onto "special" paper (.. onto stuff I found in my mailbox as advertisments)
I laminate that with modified office laminator onto cooper clad.
.. soak in hot watter few minutes
.. pell off paper
.. etch.. (I use 1/3 H2O, 1/3 HCL, 1/3 H2O2) in smallest possible quantity. (just to cover PCB while etching)
I simple therm....
.. pell off paper
28 Mar 2010 14:43 - 28 Mar 2010 14:45 #2463
by eslavko
.... as usual 1'st board has few mistakes. So here is new schematic and board layout. Now the Board is tested. It's works as should be. Now need the time/knowledge to write driver.
For now I just rumbled in emc sources and get very confused... C is realy not my language
Last edit: 28 Mar 2010 14:45 by eslavko.
Time to create page: 0.317 seconds
