RT-8p8c - An ethernet based interface for LinuxCNC
19 Sep 2012 00:28 #24397 by fmederos
So you are not enabling RTnet's TDMA discipline?
Seems not to be needed as the board does not talk unless asked, you may just daisy-chain several of these without collisions...
I wonder how would you manage the 100uSec ask-reply delay if you were to implement a closed-loop. You would ask on one iteration of the rt-thread and use the reply on the following itaration?
Regards,
Fernando
19 Sep 2012 01:18 #24399 by kinsa
I'm not using TDMA. There's just a single "user" in this case.
Or have the board serve as a gateway to other devices so that there will be no network contention.
Start the sequence with a TX then RX with the initial read value discarded. Then adjust the reply delay such that by the time the READ thread starts a reply is already waiting.
[WRITE THREAD] TX -> reply delay -> RX [READ THREAD] --> Process --> [WRITE THREAD] TX -> delay -> RX [READ THREAD] --> ...
Regards,
GP
19 Sep 2012 02:11 #24401 by fmederos
I see, the tunable delayed reply is good!
In fact what is needed is a delayed "measurement-and-reply" not just reply, so the data used by the PID routine is as fresh as possible.
Things might get complicated managing different delays when several boards are connected, unless ring-virtual-topology is used as you suggested...
Regards,
Fernando
19 Sep 2012 02:20 #24402 by kinsa
Yes, it's a delay before measurement and reply.
Note that ~100us is tx and rx combined. This time can be reduced if the PIC32 workload is also reduced.
Regards,
Fernando
Play with one board at a time. :)
19 Sep 2012 09:53 #24409 by jimlas53
Do you have any particular reason for the selection of PIC? I assume because it was the one on the demo kit?
I'm thinking of a servo interface instead of steppers, which requires more hardware (D/A, encoder tracking) but I like the approach you've taken.
Doug
19 Sep 2012 10:16 #24410 by kinsa
Doug
I actually started with the enc28j60 board that I had before progressing to the fastest ethernet enabled chip that Microchip had.
I choose stepgen because I just want to control my MF70 mill. I don't like to use the thick LPT cable. ;)
The other nice thing about PIC32 is the built-in DMA which helps a lot if you want to offload the processing to another chip/fpga. The PIC32 just serves as a high speed bridge to whatever driver board you want to use.
GP
19 Sep 2012 10:39 #24412 by jimlas53
I have several routers using stepgen and they work great (with the big LPT cable!). I just acquired an old SMT assembly machine which has a good X-Y ballscrew/servo setup, including the servo amps. So I need a servo control interface. I would be interested in testing your board/firmware on one of my stepper machines, which will help me get familiar with the code, something I'll need for a servo interface. Can I buy a board?
Doug
19 Sep 2012 11:01 #24413 by kinsa
jimlas53 wrote:
Can I buy a board?
Once the hardware and software are stable and tested. Everything is still in alpha-stage. I haven't hooked it up to a real machine yet; the only connection it had is to my scope.
The real motivation behind this is to actually develop a working RTnet hal driver so that the big guys can come in and start making good stuff.
GP
19 Sep 2012 12:31 #24415 by jimlas53
I'd be happy with a bare board - I build SMD PC boards every day and do some PIC programming, so no problem there.
Doug
19 Sep 2012 12:58 #24417 by andypugh
This might already be happening, to support the Mesa 7i80
( www.mesanet.com/fpgacardinfo.html )
Moderators: PCWjmelson
Time to create page: 0.178 seconds
