7i80 and 7i77
12 Aug 2015 22:54 - 12 Aug 2015 22:58 #61344 by PCW
Replied by PCW on topic 7i80 and 7i77
For the record let me tell you that when I first tried to flash the 7i80db_25_7i76x2_7i77x2.bit I got errors
then I realized the existence of 7i80db_25_7i76x2_7i77x2D.bit (note the "D" at the end) and that one flashed ok
later guessed that the "D" probably had to do with 7i80"D"B ...
Now, to flash 7i80db_25_7i77x4.bit I thought I would need something like 7i80db_25_7i77x4D.bit, but coludn't find that file
any idea what the "D" stands for ?
The card type is indicated by the card name in the bitfile. for example filenames that start with 7i80db_25 are for 7i80db-25s and filenames that start with 7i80hd_16 are for a 7i80hd-16.
The rest of the file name indicates the configuration either by code letters for the modules contained or by specifying daughtercards. Daughtercards are specified in connector order
You can check the current configuration pinout to verify that it matches your daughtercard pinout with mesaflash:
mesaflash --device 7i80 --addr 192.168.1.121 --readhmid
Again, for a single 7I77, I would use the 7i77x4 config and connect the 7I77 to P2
Last edit: 12 Aug 2015 22:58 by PCW.
12 Aug 2015 23:01 #61345 by franco_uy
Replied by franco_uy on topic 7i80 and 7i77
Thanks again Andy,
could't find information on fielpower stuff :(
don't have a clue what is VIN ... :S :laugh:
is there a place i can find info on this topics ? :dry:
to continue anyway...
is it just a matter of hooking a DC power supply like
ground negative to TB2 pin 8 and + DC ie 24V to TB2 pin 1
i can do that right away... im kinda exited ! :woohoo:
12 Aug 2015 23:06 #61346 by andypugh
Replied by andypugh on topic 7i80 and 7i77
I assume you already have www.mesanet.com/pdf/parallel/7i77man.pdf ?
I think so. Just make absolutely sure that you have the wires round the right way. You can unambiguously identify PIN1 by the fact it has a square solder pad underneath.
12 Aug 2015 23:49 #61348 by franco_uy
yes I already have the manual...haha
I've just connected fieldpower and besides two new leds (steady lit on red and yellow), I don't see any other difference ...
ie still looking for some pin with ..7i77...
should I see them now ?
related to the readhmid, got it too
I, guess the board is still alive :)
5 yellow leds and 1 red, on
and no activity now on the pins i mentioned before
if i sent some pics will be helpful ?
13 Aug 2015 00:49 #61349 by PCW
some questions:
Which bit file?
To which 7I80DB connector is the 7I77 connected?
Did you verify the current 7I80DB pinout with mesaflash?
How is the 7I77 getting 5V power?
13 Aug 2015 00:50 #61350 by franco_uy
Great PCW !!
seems that don't having any 7i76 connected, generates some problem to the 7i80db_25_7i76x2_7i77x2D.bit
I've flashed
went back on to J2
and now I CAN SEE THE PINS !!! :woohoo:
AND CR15 blinking :blink: :blink: :blink: green !
thanks !
btw I now have to figure out how to solve this i guess
have a these messages
hm2/hm2_7i80.0: Warning: sserial remote device 7i77 channel 0 has old firmware that should be updated
hm2/hm2_7i80.0: Warning: sserial remote device 7i77 channel 1 has old firmware that should be updated
13 Aug 2015 01:10 #61351 by franco_uy
sorry i missed to paste the bin I flashed
it is 7i80db_25_7i77x4.bit
and for the record
the 7i77 is getting its power from the 7i80DB via the db25 cable/patchcord jumpers accordingly
the readhmid cmd gives
BoardName : MESA7I80
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 4
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
then the modules and then the pins
I couldn't see any info regaring version
also run
franco@knanolcnc:~$ mesaflash --device 7I80 --sserial
SSLBP port 0:
interface type: aa
interface width: 8
SSLBP Version: 1.43
SSLBP Channel Start: 112
SSLBP Channel Stride: 50
SSLBP Processor Type: d8
SSLBP Channels: 6
SSLBP Baud Rate: 2500000
SSLBP Clock: 100 MHz
device at channel 0: 7I77 (unit 0x120000DA)
device at channel 1: 7I77 (unit 0x110000DA)
what is stride ? should I know ? :blush:
what do i do with the
13 Aug 2015 01:12 #61352 by PCW
You dont need to have a 7I76 connected to use a 7I76x2_7I77x2 config but the command line is a bit different (since the 7I77s are on the second sserial port)
The following user(s) said Thank You: franco_uy
13 Aug 2015 01:13 #61353 by andypugh
For the moment, ignore it.
13 Aug 2015 01:28 #61354 by franco_uy
ok Andy i will ignore that for now :). tnks !
PCW: you mean the sserial_port_N= option in the hm2_pci modparam and that stuff ?
I read the linuxcnc.org/docs/html/man/man9/hostmot2.9.html
seems a matter of playing with modes and X. is that ?
if it's that the point I'll try to remember that because i foresee I'll need it in the future...
I could't get all the ide behind sserial - besides the proprietary thing and the 2.5Mhz, anyway
just to know..., is there any other source of info on this topic ? just curious ..
I'll try to dig now into the pins world, the encoders, drivers etc
But today.. You helped me out to make my day !
many many thanks !
Moderators: PCWjmelson
Time to create page: 0.121 seconds
