7i80 and 7i77
20 Sep 2015 00:19 #62788
by jeeybee
Replied by jeeybee on topic 7i80 and 7i77
Expect for one of the links I had to replace with a new address it worked until
sudo make modules_install
I got:
cp: kan inte ta status på ”./modules.builtin”: Filen eller katalogen finns inte
make: *** [_modinst_] Fel 1
In Swedish this is, can not take status on blablabla file or folder do not exist or something
I got:
20 Sep 2015 00:27 - 20 Sep 2015 00:37 #62789
Replied by PCW on topic 7i80 and 7i77
Did it start installing modules at stop in the middle or did stop at the beginning?
(Though at this point would probably just give up on that PC as unsuitable for preempt-RT)
Are you sure you dont have a hardware problem on you system (bad drive perhaps)
Last edit: 20 Sep 2015 00:37 by PCW.
20 Sep 2015 00:34 - 20 Sep 2015 00:36 #62790
by jeeybee
Yes but I still have some motivation left
I ran every row separately so I could see were it went wrong and its only that command that doesnt work and give the error.
I also tried it in a new terminal and then I got a different error
make: *** no rule fot to create the target "modules_install" (also translated from swedish)
edit: Damn it was no space left on the drive :/ have to free it upp a bit and try again (its a very small hard drive on it)
Last edit: 20 Sep 2015 00:36 by jeeybee.
20 Sep 2015 01:00 #62792
The default .config installs a bazzilions of drivers so takes gigabytes of space...
20 Sep 2015 17:20 #62804
by jeeybee
Woohoo the patch did the trick!!
No I get 28207ns after one hour of youtubing.
Thank you soo much for your help all of you.
- Razor_keen
- Thank you received: 4
01 Nov 2015 14:18 #64570
by Razor_keen
Replied by Razor_keen on topic 7i80 and 7i77
i was following your syntax and ran into an error and was wondering if you knew how i could correct it. upon enterink make xconfig, term returned the following
<mymachine>rtlinux/linux-4.1.5$ make xconfig
HOSTCC scripts/basic/fixdep
CHECK qt
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
MOC scripts/kconfig/qconf.moc
HOSTCXX scripts/kconfig/qconf.o
HOSTLD scripts/kconfig/qconf
scripts/kconfig/qconf Kconfig
# using defaults found in /boot/config-3.13.0-66-generic
/boot/config-3.13.0-66-generic:5252:warning: symbol value 'm' invalid for USB_ISP1760_HCD
/boot/config-3.13.0-66-generic:6518:warning: symbol value 'm' invalid for VME_BUS
/boot/config-3.13.0-66-generic:6551:warning: symbol value 'm' invalid for GENERIC_PHY
it seems i could place a new config file here? im sure this is probably user error on my end but any help would be greatly appreciated.
CHECK qt
02 Nov 2015 00:09 - 02 Nov 2015 00:10 #64583
Those are just warnings so probably harmless
You do need to make sure that the RT patch applied (it also patches .config)
You can check by making sure fully preempt-able kernel is selected in the
processor type and features/preemption model section (of xconfig)
Last edit: 02 Nov 2015 00:10 by PCW.
The following user(s) said Thank You: Razor_keen
- Razor_keen
02 Nov 2015 04:46 #64592
by Razor_keen
I was wanting to use a .config file from a previous patch and it seems I was also missing the fact that my system is a 64bit system. Do you foresee any problems with me simply changing that option (at the top of xconfig menu)?
I'm sorry if this is a noob question, It's just a lot to learn in a short period of time.
Thanks in advance,
Jason
Thanks in advance,
Jason
11 Nov 2015 11:22 - 11 Nov 2015 11:24 #65116
by perra_e
Replied by perra_e on topic 7i80 and 7i77
Does any one know if I have to add a 7i78 Step dir board to the 7i80 if I want to controle a step motor? The step motor should be for an ATC so it is not for motion control of the mill. I hope I can use the 7i77 for this.
--Per
--Per
Last edit: 11 Nov 2015 11:24 by perra_e.
11 Nov 2015 11:40 #65117
Replied by andypugh on topic 7i80 and 7i77
If 500Hz is fast enough (and it might well be) then you can use the software step-generator to drive GPIO pins on the 7i77.
Time to create page: 0.594 seconds
