Mesa Cards and Inductive Proximity Switches
25 Nov 2016 15:08 - 25 Nov 2016 15:13 #83277 by PCW
Using the expansion connector pins directly will work with NPN proximity switches
(the expansion port pins have pull-ups to 5V)
_BUT_ if you make a wiring mistake (connecting to >7V or < -0.5V) even for a microsecond
or you have a EMI issue and large voltage spikes on the wiring, you will damage the FPGA
Safer to use the field inputs with a 2K 1 W pullup to 24V
Last edit: 25 Nov 2016 15:13 by PCW.
Moderators: PCWjmelson
Time to create page: 0.109 seconds
