DB25 breakout board
04 Jan 2017 04:07 - 05 Jan 2017 00:38 #85183
Replied by rodw on topic DB25 breakout board
This document is buried on the forum here somewhere.
www.google.com.au/url?sa=t&source=web&rc...qQNjGt7L5iKEhp6fYhpQ
Its the best info I found but you can't alter the outputs to inputs.
Last edit: 05 Jan 2017 00:38 by rodw.
04 Jan 2017 19:59 #85249
by kagouraki
Replied by kagouraki on topic DB25 breakout board
Can you please point me in a direction for these inexpensive bob's ?
One or two link are appreciated!
Thank you !
Thank you !
04 Jan 2017 21:19 #85253
Mine came off eBay from Longs Motor as a kit with 4 x DM542A stepper drives. Here's a listing
www.ebay.com/itm/breakout-board-DB25-for...1:g:xMgAAOSwqfNXjxQq
But look around first as I think there are multiple suppliers.
Thank you !
04 Jan 2017 21:23 #85254
by kagouraki
this one is not working as input... i am looking for one that is working for input. I mean configure the parport as input and not as output
- Thank you received: 1369
04 Jan 2017 22:13 #85260
Replied by Todd Zuercher on topic DB25 breakout board
I've had good luck with these.
cnc4pc.com/motion-control/breakout-board...-interface-card.html
04 Jan 2017 22:55 #85261
by kagouraki
30 dollars...hhhmmmm
It is not so cheap...
I think i am going to connect them directly without bob. Is there any problem ? They are only switces with external pull ups. No relays or motors
05 Jan 2017 03:41 #85270
There are straight through unprotected screw terminal breakouts fairly cheaply, that you can wire however you like.
www.ebay.com/itm/DB25-MG6-Male-Female-He...p2141725.m3641.l6368
Funny, I said there are others, but darned if I can find any now.
05 Jan 2017 15:20 #85291
It wouldn't particularly worry me to do that.
You could make an opto-isolation board very easily if you wanted, too. Just use some strip-board.
Replied by andypugh on topic DB25 breakout board
Time to create page: 0.130 seconds
