5i25 7i76 Question
15 Feb 2016 17:14 #70170 by Clive s
Clive s replied the topic: 5i25 7i76 Question
Thank you for being so direct and clear Clive
01 Mar 2017 05:57 - 01 Mar 2017 05:59 #88795 by usert_l
usert_l replied the topic: 5i25 7i76 Question
Hello,
I'm also setting up my 7i76 board and hope it's OK to post a question here, because we're on the same topic. When choosing a 24v power supply for the I/O is there any particular spec or design I should look for? Like for example, should I look for a regulated power supply, what should be minimum current rating, how much voltage ripple is acceptable? My apology if this has been asked before but I don't think the manual talks about it...
- Tim
Last Edit: 01 Mar 2017 05:59 by usert_l.
01 Mar 2017 08:57 #88798 by Clive s
I tend you use this type of course they can be got in various amps ratings
www.aliexpress.com/item/60W-output-24VDC...40010308.4.30.jFbkSB
The following user(s) said Thank You: usert_l
01 Mar 2017 10:59 #88801 by tommylight
tommylight replied the topic: 5i25 7i76 Question
I exlusively use laptop adapters for a lot of things, and original phone chargers for 5V. All newer laptop adapters are 20V 3A, 4.5A, 6A and some Dell even 12A. Fully regulated with all the protections included and work from 110V to 270V mains. I get used ones for 15 euro a piece from computer services.
Moderators: PCWjmelson
Time to create page: 0.075 seconds
