5i25/7i77 with Fanuc 3 axis servo drive Problems
- PotbellyMachine1
27 Oct 2016 17:03 #82144
by PotbellyMachine1
Replied by PotbellyMachine1 on topic 5i25/7i77 with Fanuc 3 axis servo drive Problems
I have done some experimenting in the HAL.
I do have the enable pin in my hal.
I used the net command to connect spindle-out to analogout4 in addition to analogout5 and it shows output voltage.
Still nothing on output5
I am not physically using the enable on output5 this would not make a difference would it?
I suppose I could just use output from #4 but I would like to know why 5 doesn't work....
- PotbellyMachine1
27 Oct 2016 17:22 #82148
by PotbellyMachine1
Perhaps I should mention when I run PNCCONF that the option for axis 5 out only has one drop down where the others show 2. (I think the others have one you can change and one grayed out)
27 Oct 2016 17:28 #82150
Replied by PCW on topic 5i25/7i77 with Fanuc 3 axis servo drive Problems
In general I would not setup a closed loop spindle for a first shot at getting this going,
but this is an issue:
MAX_OUTPUT = 10.0
ENCODER_SCALE = 400.0
OUTPUT_SCALE = 8000
OUTPUT_MIN_LIMIT = -8000
OUTPUT_MAX_LIMIT = 8000
This means the maximum output voltage will be 10/8000 V = 12 mv
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 8000
- PotbellyMachine1
27 Oct 2016 19:13 #82155
by PotbellyMachine1
Got it working.........
Cincinnati was kind enough to wire the encoder for the spindle different from the XYZ motors.
Same cable and plug but for the XYZ red and black pair is index. On spindle red and black is apparently A. B was the same as before and I did not yet attempt to reattach index.....
Time to create page: 0.261 seconds
