Need help for select mesa boards
21 Oct 2016 16:49 #81921
by Ludwig
Need help for select mesa boards was created by Ludwig
Hello LINUXCNC user,
I have a 5i25 with 7i76 working very well on my machine.
Now I recive a 7i52 to connect some encoders to make a close loop system for my 5 axis machine and find out, I can not connect this board to my exist 5i25.
Please tell me, withch board I have to Change.
Thanks in advance.
Ludwig
Thanks in advance.
Ludwig
- Thank you received: 1369
21 Oct 2016 17:21 #81923
Replied by Todd Zuercher on topic Need help for select mesa boards
How many encoders do you need to connect? The 7i85 would be the DB25 port equivalent of the 7i52, but it only supports 4 encoders. To use the 7i52 you would need to get a mesa board that supprts it like a 5i24, but to use the 7i76 with a 5i24 you would also need an adapter store.mesanet.com/index.php?route=produc...rt=p.price&order=ASC
21 Oct 2016 21:02 #81929
by Ludwig
Replied by Ludwig on topic Need help for select mesa boards
Hi Todd,
thanks very much. That it was Iooking for.I need 5 Encoder. I will order a 5i24 and the HD-DB Adapter.
Best regards.
Ludwig
Best regards.
Ludwig
22 Oct 2016 01:11 #81931
Remember the 7i76 has one encoder input as well. (and there might be the possibility of using 2 or 3 of the RS422 inputs on a 7i85 to read an encoder (would take a custom firmware). I'd suggest talking to Peter to get his opinion on your best solution..
Time to create page: 0.360 seconds
