troubleshooting 5i25/7i76 combination
19 Nov 2016 15:35 #82988
by cts1085
troubleshooting 5i25/7i76 combination was created by cts1085
Here is a brief history: got the kit from mesaus, flashed the 5i25 with the 5i25_7i67x2.bit and on the bench was able to see the pins for the 7i76 - even tested vfd/stepgens for one axis and spindle.
Now I have the 7i76 mounted in a case (with field power 24v to pin 1 and common to pin 8. I have both LED's lit on the 7i76 but I do not see the pins with the show pin command. When I try the --readhmid from the mesaflash i get the below output - what else can I check????
And yes, reapplied flash and powercycled everything several times.
cts@deb-linuxcnc:~$ sudo mesaflash --device 5i25 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)
19 Nov 2016 15:47 - 19 Nov 2016 15:47 #82989
Replied by PCW on topic troubleshooting 5i25/7i76 combination
If the 7I76 field I/O pins dont appear (and you have field power)
make sure that the 7I76 W1 and W3 are in the left hand position
and that the 7I76 is connected to 5I25 P3 with a IEEE1284 cable
Also make sure the the 5I25 and 7I76 5V cable power jumpers
are correct for the power mode
7I76 5V from 5I25:
7I76 W2 LEFT
5I25 W2 UP
External 7I76 5V:
7I76 W2 RIGHT
5I25 W2 DOWN
7I76 5V from 5I25:
7I76 W2 LEFT
5I25 W2 UP
External 7I76 5V:
7I76 W2 RIGHT
5I25 W2 DOWN
Last edit: 19 Nov 2016 15:47 by PCW.
19 Nov 2016 16:44 - 19 Nov 2016 16:55 #82992
by cts1085
Replied by cts1085 on topic troubleshooting 5i25/7i76 combination
ok - i am using the ieee parallel cable that came with the kit. the jumpers are:
5i25 w1-dn, w2-up, w3-up, w4-up, w5-up
7i76 w1-left, w2-left, w3-left, w4-right, w5-right, w6-right
I am expecting 5v from the 5i25 to the 7i76 - i have applied 24v field pwr to 7i76
And both LED's are lit.
What is next?
What is next?
Last edit: 19 Nov 2016 16:55 by cts1085.
19 Nov 2016 16:45 #82993
by cts1085
QQ - Does it matter what the power up order is? - 7i76 before 5i25 or after?
19 Nov 2016 16:56 #82995
No power up order is unimportant but all power must be there before linuxcnc starts
what does
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
halcmd: show all
report?
what does
halrun
halcmd: show all
report?
19 Nov 2016 17:11 - 19 Nov 2016 17:13 #82996
by cts1085
Here is the output:
cts@deb-linuxcnc:~$ halrun
halcmd: show all
Loaded HAL Components:
ID Type Name PID State
5 RT hm2_pci ready
3 User halcmd4014 4014 ready
4 RT hostmot2 ready
Component Pins:
Owner Type Dir Value Name
5 s32 OUT 0 hm2_5i25.0.encoder.00.count
5 s32 OUT 0 hm2_5i25.0.encoder.00.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.00.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.00.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-index
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.00.position
5 float OUT 0 hm2_5i25.0.encoder.00.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.00.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.00.quad-error-enable
5 s32 OUT 1 hm2_5i25.0.encoder.00.rawcounts
5 s32 OUT 1 hm2_5i25.0.encoder.00.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.00.reset
5 float OUT 0 hm2_5i25.0.encoder.00.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.01.count
5 s32 OUT 0 hm2_5i25.0.encoder.01.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.01.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.01.input-index
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.01.position
5 float OUT 0 hm2_5i25.0.encoder.01.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.01.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.01.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.01.reset
5 float OUT 0 hm2_5i25.0.encoder.01.velocity
5 u32 IN 0x00001FC8 hm2_5i25.0.encoder.sample-frequency
5 bit OUT FALSE hm2_5i25.0.gpio.000.in
5 bit OUT TRUE hm2_5i25.0.gpio.000.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.001.in
5 bit OUT TRUE hm2_5i25.0.gpio.001.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.002.in
5 bit OUT TRUE hm2_5i25.0.gpio.002.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.003.in
5 bit OUT TRUE hm2_5i25.0.gpio.003.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.004.in
5 bit OUT TRUE hm2_5i25.0.gpio.004.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.005.in
5 bit OUT TRUE hm2_5i25.0.gpio.005.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.006.in
5 bit OUT TRUE hm2_5i25.0.gpio.006.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.007.in
5 bit OUT TRUE hm2_5i25.0.gpio.007.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.008.in
5 bit OUT TRUE hm2_5i25.0.gpio.008.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.009.in
5 bit OUT TRUE hm2_5i25.0.gpio.009.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.010.in
5 bit OUT FALSE hm2_5i25.0.gpio.010.in_not
5 bit IN FALSE hm2_5i25.0.gpio.010.out
5 bit OUT FALSE hm2_5i25.0.gpio.011.in
5 bit OUT TRUE hm2_5i25.0.gpio.011.in_not
5 bit IN FALSE hm2_5i25.0.gpio.011.out
5 bit OUT TRUE hm2_5i25.0.gpio.012.in
5 bit OUT FALSE hm2_5i25.0.gpio.012.in_not
5 bit IN FALSE hm2_5i25.0.gpio.012.out
5 bit OUT TRUE hm2_5i25.0.gpio.013.in
5 bit OUT FALSE hm2_5i25.0.gpio.013.in_not
5 bit IN FALSE hm2_5i25.0.gpio.013.out
5 bit OUT TRUE hm2_5i25.0.gpio.014.in
5 bit OUT FALSE hm2_5i25.0.gpio.014.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.015.in
5 bit OUT TRUE hm2_5i25.0.gpio.015.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.016.in
5 bit OUT FALSE hm2_5i25.0.gpio.016.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.017.in
5 bit OUT TRUE hm2_5i25.0.gpio.017.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.018.in
5 bit OUT TRUE hm2_5i25.0.gpio.018.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.019.in
5 bit OUT TRUE hm2_5i25.0.gpio.019.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.020.in
5 bit OUT TRUE hm2_5i25.0.gpio.020.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.021.in
5 bit OUT TRUE hm2_5i25.0.gpio.021.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.022.in
5 bit OUT TRUE hm2_5i25.0.gpio.022.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.023.in
5 bit OUT TRUE hm2_5i25.0.gpio.023.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.024.in
5 bit OUT TRUE hm2_5i25.0.gpio.024.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.025.in
5 bit OUT TRUE hm2_5i25.0.gpio.025.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.026.in
5 bit OUT TRUE hm2_5i25.0.gpio.026.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.027.in
5 bit OUT FALSE hm2_5i25.0.gpio.027.in_not
5 bit IN FALSE hm2_5i25.0.gpio.027.out
5 bit OUT TRUE hm2_5i25.0.gpio.028.in
5 bit OUT FALSE hm2_5i25.0.gpio.028.in_not
5 bit IN FALSE hm2_5i25.0.gpio.028.out
5 bit OUT TRUE hm2_5i25.0.gpio.029.in
5 bit OUT FALSE hm2_5i25.0.gpio.029.in_not
5 bit IN FALSE hm2_5i25.0.gpio.029.out
5 bit OUT TRUE hm2_5i25.0.gpio.030.in
5 bit OUT FALSE hm2_5i25.0.gpio.030.in_not
5 bit IN FALSE hm2_5i25.0.gpio.030.out
5 bit OUT TRUE hm2_5i25.0.gpio.031.in
5 bit OUT FALSE hm2_5i25.0.gpio.031.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.032.in
5 bit OUT FALSE hm2_5i25.0.gpio.032.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.033.in
5 bit OUT FALSE hm2_5i25.0.gpio.033.in_not
5 bit IN FALSE hm2_5i25.0.led.CR01
5 bit IN FALSE hm2_5i25.0.led.CR02
5 s32 OUT 0 hm2_5i25.0.read.time
5 s32 OUT 0 hm2_5i25.0.read_gpio.time
5 bit IN FALSE hm2_5i25.0.stepgen.00.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.00.counts
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.00.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.00.enable
5 float IN 0 hm2_5i25.0.stepgen.00.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.position-fb
5 float IN 0 hm2_5i25.0.stepgen.00.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.01.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.01.counts
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.01.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.01.enable
5 float IN 0 hm2_5i25.0.stepgen.01.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.position-fb
5 float IN 0 hm2_5i25.0.stepgen.01.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.02.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.02.counts
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.02.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.02.enable
5 float IN 0 hm2_5i25.0.stepgen.02.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.position-fb
5 float IN 0 hm2_5i25.0.stepgen.02.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.03.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.03.counts
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.03.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.03.enable
5 float IN 0 hm2_5i25.0.stepgen.03.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.position-fb
5 float IN 0 hm2_5i25.0.stepgen.03.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.04.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.04.counts
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.04.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.04.enable
5 float IN 0 hm2_5i25.0.stepgen.04.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.position-fb
5 float IN 0 hm2_5i25.0.stepgen.04.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.05.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.05.counts
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.05.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.05.enable
5 float IN 0 hm2_5i25.0.stepgen.05.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.position-fb
5 float IN 0 hm2_5i25.0.stepgen.05.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.06.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.06.counts
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.06.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.06.enable
5 float IN 0 hm2_5i25.0.stepgen.06.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.position-fb
5 float IN 0 hm2_5i25.0.stepgen.06.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.07.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.07.counts
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.07.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.07.enable
5 float IN 0 hm2_5i25.0.stepgen.07.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.position-fb
5 float IN 0 hm2_5i25.0.stepgen.07.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.08.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.08.counts
5 float OUT 0 hm2_5i25.0.stepgen.08.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.08.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.08.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.08.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.08.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.08.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.08.enable
5 float IN 0 hm2_5i25.0.stepgen.08.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.08.position-fb
5 float IN 0 hm2_5i25.0.stepgen.08.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.08.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.09.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.09.counts
5 float OUT 0 hm2_5i25.0.stepgen.09.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.09.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.09.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.09.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.09.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.09.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.09.enable
5 float IN 0 hm2_5i25.0.stepgen.09.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.09.position-fb
5 float IN 0 hm2_5i25.0.stepgen.09.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.09.velocity-fb
5 bit I/O FALSE hm2_5i25.0.watchdog.has_bit
5 s32 OUT 0 hm2_5i25.0.write.time
5 s32 OUT 0 hm2_5i25.0.write_gpio.time
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
5 bit RW FALSE hm2_5i25.0.encoder.00.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.00.filter
5 bit RW FALSE hm2_5i25.0.encoder.00.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.00.scale
5 float RW 0.5 hm2_5i25.0.encoder.00.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.01.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.01.filter
5 bit RW FALSE hm2_5i25.0.encoder.01.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.01.scale
5 float RW 0.5 hm2_5i25.0.encoder.01.vel-timeout
5 bit RW FALSE hm2_5i25.0.gpio.000.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.000.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.001.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.001.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.002.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.002.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.003.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.003.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.004.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.004.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.005.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.005.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.006.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.006.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.007.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.007.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.008.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.008.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.009.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.009.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.010.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.010.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.010.is_output
5 bit RW FALSE hm2_5i25.0.gpio.011.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.011.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.011.is_output
5 bit RW FALSE hm2_5i25.0.gpio.012.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.012.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.012.is_output
5 bit RW FALSE hm2_5i25.0.gpio.013.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.013.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.013.is_output
5 bit RW FALSE hm2_5i25.0.gpio.017.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.017.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.018.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.018.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.019.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.019.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.020.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.020.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.021.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.021.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.022.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.022.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.023.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.023.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.024.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.024.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.025.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.025.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.026.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.026.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.027.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.027.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.027.is_output
5 bit RW FALSE hm2_5i25.0.gpio.028.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.028.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.028.is_output
5 bit RW FALSE hm2_5i25.0.gpio.029.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.029.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.029.is_output
5 bit RW FALSE hm2_5i25.0.gpio.030.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.030.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.030.is_output
5 bit RW FALSE hm2_5i25.0.io_error
5 s32 RW 0 hm2_5i25.0.read.tmax
5 bit RO FALSE hm2_5i25.0.read.tmax-increased
5 s32 RW 0 hm2_5i25.0.read_gpio.tmax
5 bit RO FALSE hm2_5i25.0.read_gpio.tmax-increased
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.00.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.00.maxvel
5 float RW 1 hm2_5i25.0.stepgen.00.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.01.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.01.maxvel
5 float RW 1 hm2_5i25.0.stepgen.01.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.02.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.02.maxvel
5 float RW 1 hm2_5i25.0.stepgen.02.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.03.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.03.maxvel
5 float RW 1 hm2_5i25.0.stepgen.03.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.04.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.04.maxvel
5 float RW 1 hm2_5i25.0.stepgen.04.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.05.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.05.maxvel
5 float RW 1 hm2_5i25.0.stepgen.05.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.06.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.06.maxvel
5 float RW 1 hm2_5i25.0.stepgen.06.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.07.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.07.maxvel
5 float RW 1 hm2_5i25.0.stepgen.07.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.08.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.08.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.08.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.08.maxvel
5 float RW 1 hm2_5i25.0.stepgen.08.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.08.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.08.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.08.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.08.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.08.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.08.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.08.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.09.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.09.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.09.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.09.maxvel
5 float RW 1 hm2_5i25.0.stepgen.09.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.09.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.09.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.09.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.09.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.09.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.09.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.09.table-data-3
5 u32 RW 0x004C4B40 hm2_5i25.0.watchdog.timeout_ns
5 s32 RW 0 hm2_5i25.0.write.tmax
5 bit RO FALSE hm2_5i25.0.write.tmax-increased
5 s32 RW 0 hm2_5i25.0.write_gpio.tmax
5 bit RO FALSE hm2_5i25.0.write_gpio.tmax-increased
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
00005 f88e9890 f3704000 YES 0 hm2_5i25.0.read
00005 f88e9500 f3704000 YES 0 hm2_5i25.0.read_gpio
00005 f88e9760 f3704000 YES 0 hm2_5i25.0.write
00005 f88e9730 f3704000 YES 0 hm2_5i25.0.write_gpio
Realtime Threads:
Period FP Name ( Time, Max-Time )
Last edit: 19 Nov 2016 17:13 by cts1085. Reason: ensure power was on....
19 Nov 2016 17:48 #82997
OK so no sserial, so like a hardware issue with the 5I25/7I76/cable so they should probably be returned as a set for evaluation
Time to create page: 0.081 seconds
