7i77 5i25 hm2_pci unloaded
24 Nov 2016 17:45 #83225
Replied by PCW on topic 7i77 5i25 hm2_pci unloaded
Not a real time kernel?
you probably have to build a Preempt-rt kernel if ubuntu does not supply one
The following user(s) said Thank You: bkt
24 Nov 2016 17:49 #83226
Replied by andypugh on topic 7i77 5i25 hm2_pci unloaded
Which variant did you get from the buildbot?
LinuxCNC is not finding a kernel that it recognises as having Realtime.
I guess you followed the instructions here?
forum.linuxcnc.org/forum/27-driver-board...7i77?start=180#62783
Did every step complete without error?
24 Nov 2016 17:58 #83227
by bkt
Replied by bkt on topic 7i77 5i25 hm2_pci unloaded
Sorry PCW .... I'm on preemp_rt 4.4.27 on ubuntu 14.04 .... I've compiled the kernel and apply the pacth ..... but linuxcnc run out of rtai .... why?
Please be patient ... now as now I decide if buy more mesa card or not .... depends on linuxcnc ... I took the courage to do this by following your instructions. I thought: pcw work into mesa it does he will know what it says ?? so I followed your steps and I did the installation that does not work ... you have some alternative method ?? I can install anything precompiled? You can indicate me the way? You can show me what you have installed and running with the mesa cards and has good performance to work with a robot delta ??
I've I3 3.6Ghz and 4Gb ram ... on ubuntu 10.04 2800 ns latency test ....
Regards
Giorgio
Regards
Giorgio
24 Nov 2016 18:04 - 24 Nov 2016 18:08 #83228
by bkt
@AndyPugh Tanks a lot (very lot).... I follow the same procedure but with kernel 4.4.27 .... because I've not seen that link that you posted me ... but another ... and the pacth for that isn't avaiable jet ... so I think to use a newer kernel ....
Any how all compile without error ....
If PCW recently use kernel 4.1.5 .... I try ... but the proc is very long ....
giorgio
giorgio
Last edit: 24 Nov 2016 18:08 by bkt.
24 Nov 2016 18:07 - 24 Nov 2016 18:10 #83229
by bkt
@ PCW The link posted by andypugh is old from 2015 ....
You can posted me the last rtai kernel to use??
remeber I must use for production robot (tha since 2 day ago it work fine on ubuntu 10.04)...
I use ubuntu 14.04 32 bit is Right??
giorgio
giorgio
Last edit: 24 Nov 2016 18:10 by bkt.
24 Nov 2016 18:26 #83230
I would not use a RTAI kernel but rather a Preempt-RT kernel if using Ubuntu14.04
24 Nov 2016 18:34 #83231
Which version of linuxCNC? You want the "uspace" version for a preempt-rt kernel.
24 Nov 2016 18:39 #83232
by bkt
perfect ... i use the kernel download from here ...
kernel.org
Is right? witch kernel ( 4.1-4.2-4.3-4.4-4.5??) I must use?? 32bit or not??
these step i rigth??
cd ~
sudo apt-get update
sudo apt-get install build-essential bin86 kernel-package libqt4-dev libncurses5
-dev pkg-config
mkdir rtlinux
cd rtlinux
wget ftp://ftp.kernel.org/pub/linux/kernel/v4.x/linux-4.4.27.tar.xz
wget www.kernel.org/pub/linux/kernel/projects....4.27-rt"x".patch.gz
tar -xpf linux-4.4.27.tar.xz
gunzip patch-4.4.27-rt5.patch.gz
cp patch-4.4.27-rt5.patch linux-4.4.27
cd linux-4.4.27
cat patch-4.4.27-rt5.patch | patch -p1
make xconfig
make
sudo make modules_install
sudo make install
after these:
> git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
> cd linuxcnc-dev/src
> ./autogen.sh
> ./configure --with-realtime=uspace
> make
> sudo make setuid
> source ../scripts/rip-environment
> runtests
> in my cas "0" error!!
Regards
Giorgio
kernel.org
cd ~
sudo apt-get update
-dev pkg-config
mkdir rtlinux
cd rtlinux
cd linux-4.4.27
make xconfig
make
sudo make install
after these:
> cd linuxcnc-dev/src
> ./autogen.sh
> make
> sudo make setuid
> runtests
Regards
Giorgio
24 Nov 2016 18:43 #83233
by bkt
I have use the step write before ... so now I've linuxcnc - 2.8.0 pre1 ... the same that I use in JA9 ..
probabily these is not right:
There is the right git link?
Regards
Giorgio
Regards
Giorgio
24 Nov 2016 18:43 #83234
That should all work.
It might be that when you run LinuxCNC you are running the old, installed version, not the new one you just compiled.
If you open a terminal window
cd linuxcnc-dev
, ,/scripts/rip-environment
linuxcnc
You should see
> LINUXCNC - 2.8.0~pre1
cd linuxcnc-dev
linuxcnc
You should see
Time to create page: 0.134 seconds
