Hi Driver, board help
- wanabemachinist
12 Dec 2016 20:49 #83978
by wanabemachinist
Hi Driver, board help was created by wanabemachinist
Hi i am music player. I like cnc routers. I would like to make some cnc tool some day in future.(hope nearest future).
After some googling i decided to ask here...
I need quick answer from You pro`s.
I`m offered nema 23 steppers for good price but they are 5 phase (not from that site... but that model), so...
Can i use this motor manamotor.ir/product/210479
with this driver www.google.com/url?sa=t&rct=j&q=&esrc=s&...IT6IwXQRG-_e0qI6bhdg
and all with this board
www.ebay.com/itm/1pcs-5-Axis-CNC-Breakou...4:g:cX4AAOSwvg9Xb93Q
or some other cheap mach 3 controller or arduino+some shield or something else... ?
Need quick answer because seller have other offers...
Thanks ,
Cheers..
Thanks ,
Cheers..
12 Dec 2016 21:11 #83984
Replied by andypugh on topic Hi Driver, board help
How does the current rating of the motors compare to that of the drivers?
According to a spec sheet I found on the web (attached) the drives are good for 1.4A / phase.
- Thank you received: 5909
12 Dec 2016 21:16 #83986
Replied by tommylight on topic Hi Driver, board help
That is a nice price on those drives, but i would advice to stear clear of 5 phase setups that are not a turn key option. It is not easy for begginers to figure out the wiring and those drives have plenty of options on them.
So however cheap they may seem, it is much better to get 2 phase motors and drives, and there are plenty of cheap bundles on the net.
- wanabemachinist
12 Dec 2016 21:32 - 12 Dec 2016 22:13 #83989
by wanabemachinist
Replied by wanabemachinist on topic Hi Driver, board help
thanks you both, for quick replay. ( @andypugh -i dno how???)
Anyway, my question is , is it possible (or some other driver you sugest.)
Now is time to buy this motors dirt cheap if they can be used in diy cnc project???
Cheers
@andypugh
www.google.com/url?sa=t&rct=j&q=&esrc=s&...5DflnhwF8A314fBqVyMw
csd this model 0.75 A/P check it please
Cheers
@andypugh
Last edit: 12 Dec 2016 22:13 by wanabemachinist.
12 Dec 2016 22:08 #83997
I have heard that 5-phase steppers have some advantages, but maybe harder to make to work.
- wanabemachinist
13 Dec 2016 16:38 #84043
by wanabemachinist
16 Dec 2016 01:11 #84236
Are the Slo-Syn motors definitely steppers? They look slightly servo-ish.
No idea what the big card is. Is there a makers name?
16 Dec 2016 02:42 #84245
by jmelson
Replied by jmelson on topic Hi Driver, board help
One of the detail pictures shows 5-phase drivers. These can only be used with 5-phase motors, which are only made by one company - Oriental Motor, under license from Berger-Lahr. These are not compatible with other 2-phase stepper motors.
- wanabemachinist
16 Dec 2016 14:43 #84277
by wanabemachinist
As the seller told me all parts on pictures (and many more) are from some expensive big format photo printer.
I googled a lot about those industrial parts. There are almost no wiring diagrams,or other useful schemes about these motors, drivers, ect.
So i decided to go "easier" path with 2/4 phase stepper/drivers. That is very well documented and well known topic here, and on other cnc/ 3d print communities.
Thank You all.
P.S. The seller sold everything from pic 1 meanwhile, so another reason, to buy something else.
Thank You all.
17 Dec 2016 08:04 #84309
Those are from photocopiers, they look like 5 phase motort and drives, so they are most probably specialy made for that purpose. All that i have are specialy purposed with their own controllers and some of them have separate current limiters. To date i have not seen any 5 phase that can be controlled by step/dir or up/down or quadrature signals. On the other side i had some 3 phase steppers and drives with step/dir and microsteping and enable signals.
Information above pertains to drives from photocopiers.
