Mesa 5i25 with Leadshine MX4660
19 Dec 2016 19:02 #84422
by jfclouti
Mesa 5i25 with Leadshine MX4660 was created by jfclouti
I am assembling a brand new CNC. The stepper motors will be controlled by a Leadshine MX4660 controller which has an integrated break out board.
I was thinking of buying a Mesa 5i25 and connect it directly to the Leadshine MX4660 break out board and use LinuxCNC.
I am new to all this. Would it work? Anything I should be aware of?
Thanks.
Thanks.
19 Dec 2016 19:19 #84429
Replied by andypugh on topic Mesa 5i25 with Leadshine MX4660
It ought to work, with the correct bitfile. (with a Mesa card the layout of the pins on the DB25 connector is set by the firmware, not the HAL layout.
Do you know what the pin allocation is on the drive?
The following user(s) said Thank You: jfclouti
19 Dec 2016 21:33 #84433
by jfclouti
Replied by jfclouti on topic Mesa 5i25 with Leadshine MX4660
I don't know the pin allocation, for now, but I will look for it.
I guess I will have to learn how to edit the default pin allocation of the Mesa card.
Thanks for your reply.
JFC
JFC
20 Dec 2016 10:57 #84448
Replied by PCW on topic Mesa 5i25 with Leadshine MX4660
I have a MX4660 pin-out source file, I just have not compiled a 5I25 bitfile using it.
(i think someone asked for a 7I92 bitfile for the MX4660)
I can compile a bitfile sometime this week
20 Dec 2016 12:53 #84451
by jfclouti
That would be awesome!
Thanks.
Thanks.
27 Dec 2016 00:50 #84724
Time to create page: 0.271 seconds
