Where can I get the newest firmware for 5i25 and 7i77?
- Holzwurm56
07 Jan 2017 12:37 #85397
by Holzwurm56
Where can I get the newest firmware for 5i25 and 7i77? was created by Holzwurm56
Hello,
i am using Wheezy with LinuxCNC 2.7.8 and a 5i25 and a 7i77 for my wood cnc machine, the configuration works not good. Maybe my firmware is to old. Does someone tell me where i cnc get the newest firmware for this bundle and in what way i can install it?
Hans
Hans
07 Jan 2017 13:16 #85402
by bevins
Replied by bevins on topic Where can I get the newest firmware for 5i25 and 7i77?
sudo apt-get update
sudo apt-get install mesaflash
Should get you what you need.
What is not working correctly with your machine?
07 Jan 2017 14:09 - 07 Jan 2017 14:50 #85406
Replied by PCW on topic Where can I get the newest firmware for 5i25 and 7i77?
If you bought the cards in the last year or two, the firmware is up-to-date
Its _very_ unlikely whatever issues you have are firmware related
Plotting the feedback position, commanded position, and analog out with halscope
will help you (and others here if you post a screenshot) understand why you do
not have good control of your motion and proved clues as to where to look for the trouble
Last edit: 07 Jan 2017 14:50 by PCW.
- Holzwurm56
07 Jan 2017 14:59 #85408
by Holzwurm56
Replied by Holzwurm56 on topic Where can I get the newest firmware for 5i25 and 7i77?
Hello Bevins and PCW,
i have discribed my problem in this thread: forum.linuxcnc.org/49-basic-configuratio...-more-problems#85371 . There was no firmware on the mesaboards, i load them manually with downloaded file. The 5i25 is new(i found the old not), but the 7i77 is older. I get when i start Linuxcnc the message firmware of the mesaboards old should be updated. My machine has no internetconnection, is there a file available that can i download and copy on the machine and make there the update?
It's my last idea what can be wrong on my machine.
Hello Bevins does i need for your method an internetconnection? In what directory should i open the terminal for update?
Hans
Hans
07 Jan 2017 15:12 #85409
The instructions and script for updating the 7I77 firmware is here:
mesanet.com/software/parallel/sserial.zip
To update the 7I77, unzip this file in you home directory
then
cd utils/linuxcnc
./ssinstall
./update7i77
and follow the instructions
But note: Updating the 7I77 firmware will in no way affect your problem
you have some basic analog connection or hal setup issue, nothing to do with firmware
The 7I77 firmware update only affects a rarely occurring bug that causes loss of
serial communication (you would know if this happened as you would get a string of sserial error messages)
then
cd utils/linuxcnc
./ssinstall
./update7i77
- Holzwurm56
07 Jan 2017 18:12 #85413
by Holzwurm56
Hello PCW,
I open the halscope and select: axis.1.joint-vel-cmd(1/div), axis.1.f-error(5m/div), axis.1.motor-pos-fb(500m/div), axis.1.motor-pos-cmd(500m/div).
When I move the xis with the arrowkeys there is no change on the halscopedisplay.
Hans
Hans
07 Jan 2017 18:23 #85414
is the halscope "Run Mode" set to "Roll" ?
- Holzwurm56
13 Jan 2017 15:49 #85697
by Holzwurm56
Hello,
is it necessary to update the firmware of the 5i25 too? In what kind of way i can do this?
Hans
Hans
13 Jan 2017 15:54 #85698
No, basic 5I25 firmware has been unchanged for a couple of years
13 Jan 2017 16:43 #85700
by bevins
Select the triggers you want for the different channels. Bottom right of halscope....
that you selected.Hello PCW,
Hans
