Timeout Communication Error
- pmcstoneinc
05 Feb 2017 19:15 - 05 Feb 2017 19:18 #87354
by pmcstoneinc
Replied by pmcstoneinc on topic Timeout Communication Error
Yes. I have more a feeling that with my USB-RS485 driver running on a 10ms RT thread that it can not sync or use a user space component with combined servo thread at 1ms, but that is my shot in the dark. This issue seemed to get worse once I created the user space component where I was using IO from the USB driver and IO from the 7i77 (servo thread).
Last edit: 05 Feb 2017 19:18 by pmcstoneinc.
- Thank you received: 5907
05 Feb 2017 19:18 #87355
Replied by tommylight on topic Timeout Communication Error
I added some more questions to the previous post, please read it again.
Can you disable the USB to RSxxx driver and try without it?
- pmcstoneinc
05 Feb 2017 19:20 #87356
by pmcstoneinc
Hey Tommy can you confirm what port I should be on? I thought you mean the physical port but I know what you are asking now.
- pmcstoneinc
05 Feb 2017 19:22 #87357
by pmcstoneinc
I do not seem to have mesaflash on this PC, I did flash it on a different PC once I got the boards new.
05 Feb 2017 19:26 #87358
I do mean physical port. There are 2, and depending on the firmware on the 7i92 they can be set to P2 or P3.
Had that hickup when i changed the firmware on the 6i25 so i had to connect the 7i77 to the other port.
Check readhmid, as it will show what is configured at what port.
05 Feb 2017 19:27 #87359
Sudo apt-get install mesaflash
05 Feb 2017 19:31 #87360
Replied by PCW on topic Timeout Communication Error
The sserial error 4 indicates the there is noise pickup in the cable between the 7I92 and 7I77
Either because of a ground loop or because the cable is too close to noise sources like power wiring
Updating to the latest driver will allow more tolerance of occasional extra character errors
but I'm pretty sure this driver update is in LinuxCNC only
- pmcstoneinc
05 Feb 2017 19:32 #87361
by pmcstoneinc
unable to locate package mesaflash
05 Feb 2017 19:34 #87362
What are the chances of the connector not seated properly?
- pmcstoneinc
05 Feb 2017 19:35 #87363
by pmcstoneinc
Thanks Tommy, the board initializes and allows motion. There are just certain instances that create the timeout issues, primarily during a physical estop would be one.
Time to create page: 0.101 seconds
