Mesa 5i25 & 7i76 to GE Af-300 VFD?
17 Mar 2017 01:22 #89795
by panchula
Replied by panchula on topic Mesa 5i25 & 7i76 to GE Af-300 VFD?
I did get it wired using two relays, practically identical to the wiring diagram in your post. I ended up using a DPDT for the enable so I could incorporate the enable to control other functions dependent on the spindle running -- lube pump, air motor speed adjust of the varispeed head, etc.
-Mike
-Mike
17 Mar 2017 09:02 #89805
That sort of interlocking is far easier to implement and adjust in the HAL layer than with actual wires and relays. (though it may not seem that way if you know relays but don't know HAL)
Replied by andypugh on topic Mesa 5i25 & 7i76 to GE Af-300 VFD?
28 Mar 2017 00:52 #90413
by panchula
OK Andy, now you've got me thinking... is there a way to integrate the VFD and varispeed head to get a continuous (non-back geared) low to high range utilizing both?
I'm still having trouble with the spindle not responding to F9. I did a wipe and reload (2.7.0 from the ISO, 2.7.8 via update manager) of the system to clear out any cruft. Next I created a new config -- ...and have the exact same issue. One other item is I can't get the spindle encoder to be recognized. It's a Renco 100 ppr differential. I'm seeing voltages at the pins (Fluke 77) when the spindle is running. I can drag an o'scope over if I need to.
Here are my latest ini and hal files.
Any ideas?
Any ideas?
28 Mar 2017 12:05 #90431
I would guess that the ideal is to run the motor at nominal speed where possible with speed control on the varispeed, and to only go to higher or lower frequency when out of range? Or would you prefer the opposite?
Is it just F9 that is a problem, or can you not click in the GUI either?
Almost certainly, the hardest part is likely to be deciding how you want it to work.OK Andy, now you've got me thinking... is there a way to integrate the VFD and varispeed head to get a continuous (non-back geared) low to high range utilizing both?
Under what circumstances? You probably need to be in manual mode, and might need to be homed for it to work.I'm still having trouble with the spindle not responding to F9.
As far as I can see the HAL wiring is correct. You should be able to Halscope the A and B inputs (but only at low encoder speed) and see them change state. The dmesg output will tell you which GPIO pins of the 5i25 the encoder is on.One other item is I can't get the spindle encoder to be recognized. It's a Renco 100 ppr differential. I'm seeing voltages at the pins (Fluke 77) when the spindle is running.
28 Mar 2017 14:25 #90441
Replied by PCW on topic Mesa 5i25 & 7i76 to GE Af-300 VFD?
You can read encoder pins directly (you dont need to figure out the GPIO pins)
they will look like this:
hm2_5i25.0.encoder.00.input-a
hm2_5i25.0.encoder.00.input-b
hm2_5i25.0.encoder.00.input-index
Time to create page: 0.388 seconds
