7i90 questions
01 Mar 2017 01:03 #88789
Replied by PCW on topic 7i90 questions
I think its really a driver bug
The driver should either complain that there's no config string
or work without one (like hm2_pci and hm2_eth do ) not load OK but not function
01 Mar 2017 01:05 #88790
by phillc54
Replied by phillc54 on topic 7i90 questions
I agree
01 Mar 2017 16:21 #88821
by JR1050
Replied by JR1050 on topic 7i90 questions
Id like to use this 7i90 with a 7i44 and 7i84.
would it be possible to get a bit file for 4 steppers and ssi for epp and the same config for spi? I didnt see any in the list.
01 Mar 2017 17:46 #88827
7i90_spi_sssvst8_8_8.bit
7i90_epp_sssvst8_8_8.bit
should do though the stepgen pinout may be a bit strange
01 Mar 2017 18:44 #88832
by JR1050
i have very little experience with step motors and drives. From what i can tell from the pin out generated by dmesg and the manual, I shouldn't need any kind of a special board to run the steppers, COMMX2 block should work? Maybe some sort of protection for the fpga? maybe 7i42a?
01 Mar 2017 19:05 #88836
You can drive most step motor drive step/dir inputs directly from the FPGA
If this is done its much better to use active low outputs if the motor drive allows it
(active low meaning the common optoisolator +input on the drive is tied to +5V
and the FPGA drives the - input)
The advantage of active low mode is that a full 5V drive is available
01 Mar 2017 19:55 - 01 Mar 2017 20:24 #88840
by JR1050
Im not having any luck with the above specified bit file(7i90_epp_sssvst8_8_8.bit). no step gens come up in halshow, nor ssi.
From hal file
# load low-level driver
loadrt hm2_7i90 config="num_encoders=0 num_pwmgens=0 num_stepgens=3 sserial_port_0=002xxx num_leds=0"
from dmesg
with 7i90_epp_svst4_8.bit
From hal file
from dmesg
Last edit: 01 Mar 2017 20:24 by JR1050.
01 Mar 2017 21:02 #88844
Ahh that looks like a config that didn't fit so is actually a different config
What I/O do you really need?
I can try an make a smaller config with a more reasonable pinout
01 Mar 2017 22:34 #88851
by JR1050
Right now i will be needing 2 step generators , a smart serial interface and the the rest can be i/o. I'll need one for epp and one for spi, as after this is proven out on the desktop, it will be put on a Rpi3. I intend to use a 7i44 and 7i84 for my i/o and either the 7i47 or common block for the stepper. Which spi driver should be used for the pi3? 7i90 spi or the 7i90 raspberry? Eventually I envision needing a bit file with 3 encoders, 3pwms, ssi for another small Harding lathe. It's a bit off though..
06 Mar 2017 12:51 #89091
by JR1050
PCW, have you had a chance to do the new bit files?
Time to create page: 0.497 seconds
