Inexpensive USB driver board? Arduino?
17 Feb 2017 22:01 #88133
by spinnaker
Inexpensive USB driver board? Arduino? was created by spinnaker
I am am hobbyist using Linux CNC on my cheap CNC3020 to mill printed circuit boards. The CNC3020 comes with a parallel port controller. I am looking to replace the whole controller with something that runs on USB.
I am looking for a controller board for my machine that uses USB and would work with LinuxCNC,. Since this is just a hobby I don't want to spend a ton of money. I would like to keep it around $100 US if possible.
Can anyone recommend anything?
I already have an Arduino with all of the required shields to hook to a CNC machine but I can't seem to find any software that interfaces to LinuxCNC. I did find one project here emc2arduino.wordpress.com/ but looks like it has not had much activity in a while and there does not seem to be much documentation.
Anyone know how I would interface to the Arduino, perhaps using GRBL?
17 Feb 2017 22:47 #88136
by Clive S
I am not aware of any controller than uses the USB on Linuxcnc. I think you can only use a pendant via the USB .
Replied by Clive S on topic Inexpensive USB driver board? Arduino?
23 Feb 2017 23:16 #88565
Replied by andypugh on topic Inexpensive USB driver board? Arduino?
USB isn't an option. But you could look at the Mesa 7i92 Ethernet board, and connect that to your parallel port socket.
store.mesanet.com/index.php?route=produc...83_85&product_id=306
- InMyDarkestHour
- User is blocked
- Thank you received: 111
27 Feb 2017 06:17 #88654
by InMyDarkestHour
Replied by InMyDarkestHour on topic Inexpensive USB driver board? Arduino?
GRBL doesn't require linuxcnc, there are a few "senders" around to talk with the GRBL board, AFAIK GRBL does not support backlash comp.
Another option is a Beaglebone Black running machine kit, a couple of 74LS540/541 to handle voltage translation for output signals and a couple of 74LVC245 to handle input translation, these could be wired up on a couple of "proto boards". Run Linuxcnc over ssh on your lappy and your good to go. The BBB has a couple of PRU cores that are separate to the OS that are used for step generation.
Here's a link to an upgrade to a CNC using the BBB, the author does use a commercial cape but they are simple beasts, and I'm sure an EE wouldn't have too much trouble cobbling up a homebrew one. Oh and the author does use a monitor and keyboard connected to a BBB.
Xylotex sells shields for about USD $40 plus del, I have not tried these as living on a continent that is 6 feet away from the sun shipping can almost double the price.
www.rs-online.com/designspark/upgrading-...lling-machine-part-1
But as the wiki and docs state USB is a none option for real time.
Anyhow good luck
Anyhow good luck
27 Feb 2017 09:50 #88659
If you don't want to commit to pin directions in hardware than you could probably use a GTL chip.
www.digikey.com/product-detail/en/nxp-us...68-4223-5-ND/1156316
The following user(s) said Thank You: InMyDarkestHour
Time to create page: 0.121 seconds
