- Hardware & Machines
- Driver Boards
- (NEWBIE) How to use an (Fanuc) AC Spindle servo motor for an DIY CNC router
I dont know why i forgot about that, but today when i found the servo kit on aliexpress, i wrote an mail to them to ask about that -10v - 10V and got this answer: "About your question,our servos are 0-10v, I wonder is that acceptable for you?"
So, quiet wierd i would say.
You are right, have found that. But the reason i thought to go for the Easy servo is also because i found some thread here in forum where someone had exactly that problem with the 0-10V / -10 ~ 10V.. Somehow i cant find that in my history any more, but he couldnt give them any more back and he wasnt very happy with that purchase. Have a bit fear that i will have some big problems later...
Ah, yes, I vaguely remember that now too. The manual clearly says that Bipolar Operation is possible.
forum.linuxcnc.org/27-driver-boards/3011...v-out?start=10#71671
- Thank you received: 5874
Andy, today i wrote an mail to them and ask if they have also servos and servo drivers with -10v - +10V and they replied: "we only have 0-10v servos".
And yes, thats the discussion i was talking about.
@tommylight:
Have a look at servostar 6 series, they look quite usefull with plenty of options and can be found for under 400 euro in Germany. I do not belive they can be used for induction motors, so please do check that. Pdf aplenty.
Do you mean to use them for the AXIS servos ? I have read just a bit about the Kollmorgen 600 and it sounds like they are working with mayn different encoders, so are that "Universal Servo Drivers" ? Am i right that i could buy just the servo motors and use the Kollmorgen Servostar 600 drivers?
github.com/rene-dev/stmbl
They are AC servo drives with plenty of options. If i decide to get them, i will use them for everything, meaning axis, spindle, rotary or whatever i might be building. I did not have time to study them thoroughly, but they do have everything i might need.
Where can you buy them?
Andy, i am very interested in that because, i have read something about "parts cost 70€", but i have never build boards by my own self and it sounds like you have to do it and buy every small piece of that board to create it..
@bevins: That was also my first question, but it looks like its not possible to buy it, it has to be build if i understand correctly..
Indeed, and when some parts come in reels of 100 or 4000 the price to build one is much higher than €70
I think i saw them assembled and tested for 149 somewhere, add a power supply, rectifier, capacitors, connectors and the price goes beyond a used servostar, ending up with a device that has one method of communication and ........you get the point.
I am using some PWM drives that cost 23 euro for 2 motors (11.5 for one, but two on same board), with Linuxcnc for smal servo motors and they do work, they can not replace a fully fledged servo drive.
Servostar 6 series takes 3X208 up to 3X480V so i can just plug them to 3 phase outlet at 3X380V and be done with it. Adjustable output voltage is also a very nice feature when mixing and matching to motors.
Bevins, on ebay.de is one seler that has 3 606 for 299 each and another has 1 603 i think for the same price. The rest is way north on price. Two night ago when i checked they where still there.
- Driver Boards
