- Hardware & Machines
- Driver Boards
- (NEWBIE) How to use an (Fanuc) AC Spindle servo motor for an DIY CNC router
15 Mar 2017 23:34 #89701
They have added more ways to drive then, analogue voltage, step/dir, Mesa Smart-Serial, some more I won't be using.
Replied by andypugh on topic (NEWBIE) How to use an (Fanuc) AC Spindle servo motor for an DIY CNC router
the price goes beyond a used servostar, ending up with a device that has one method of communication and ........you get the point.
- Online
- Thank you received: 5874
16 Mar 2017 00:20 #89705
Replied by tommylight on topic (NEWBIE) How to use an (Fanuc) AC Spindle servo motor for an DIY CNC router
Andy, did you or are you still using stbl? How is the overal experience? Protections? Heat? Etc
Tthank you for neverending supply of informations.
Tom
Tom
16 Mar 2017 19:01 #89767
I only decided that it was a possible solution to my current problem yesterday. So so-far know almost nothing.
21 Mar 2017 01:53 #89979
by JR1050
Replied by JR1050 on topic (NEWBIE) How to use an (Fanuc) AC Spindle servo motor for an DIY CNC router
I'm late to this. I would google the manual for that motor and its corresponding drive. If it is a red cap Fanuc spindle motor, it is a permanent magnent motor and will have no tourque with a standard vfd. Hiatachi wj-200 and Sj-300 will run a pm motor. I have the 12kw version on my Fadal with a wj-200 and it can be made to work. It is a bear to tune and you will need the pm motor addendum from hitachi to calculate the induction volatage constant and set the pm parameters correctly. I have heard that Yaskawa and Fuji also have some low priced drives that will run that motor. Pm motors make lots of current on wind down, you will need a seperate braking unit and resistor, the braking transistor in the stock wj-200 is weak and blows when hit with a big current spike. Been down that road...
- Driver Boards
