MESA 7i76 burnout
- HalaszAttila
- Thank you received: 5
22 Mar 2017 13:10 #90069
by HalaszAttila
MESA 7i76 burnout was created by HalaszAttila
Hello,
i am in big trouble. My lathe is with mesa 7i92 + 7i76. And when i turned ON the machine, one of the outputs octal driver ICs (NCV7608) is exploded.
The machine is works before, and i dont know the reason of failure.
I desoldered the exploded IC, and tested with just one, the Linuxcnc starts and dont show error message, can read the inputs, but the outputs (0-7) does`t works.
Can this card work with just one output driver IC, or PIC can detect the missing I2C device ? or maybe the cards PIC mcu broken?
22 Mar 2017 19:56 #90085
Replied by PCW on topic MESA 7i76 burnout
Both output chips share the same SPI interface CLK / DIN / DOUT signals
so if one of these pins got damaged the other output chip would not work
Its also possible that the PIC firmware senses a problem as a overload has not enabled the chips
The following user(s) said Thank You: HalaszAttila
- HalaszAttila
22 Mar 2017 20:07 #90087
by HalaszAttila
Replied by HalaszAttila on topic MESA 7i76 burnout
Ok i will try to buy and change two ICs.
I know that the warranty does`t active for these failures, but just to interest does anybody repair mesa cards?
I have broken 7i77, 7i84, and now one 7i76.
Can i send for repair, i am from Europe (Serbia).
01 Aug 2019 20:41 #141146
by svajus123
Replied by svajus123 on topic MESA 7i76 burnout
Hello! If it is still actual I can repair these boards. Including fpga replacement and programming.
- HalaszAttila
09 Aug 2019 07:34 #141719
by HalaszAttila
Hello,
yes it is actual yet. I have one 7i77 and one 7i84 broken cards.
Where are you from?
Where are you from?
- Thank you received: 5909
09 Aug 2019 12:13 #141752
Replied by tommylight on topic MESA 7i76 burnout
He is from Lithuania.
@Attila
Did i get an e-mail from you a while back about an Elumatec ?
@Attila
- HalaszAttila
09 Aug 2019 13:59 #141778
by HalaszAttila
@svajus123
Can you give me your email?
@tommylight
No i did n`t contact you about Elumatec machine.
@tommylight
09 Aug 2019 16:24 #141793
by svajus123
This email address is being protected from spambots. You need JavaScript enabled to view it.
09 Aug 2019 17:27 #141798
OK.
@tommylight
OK.
