new system with 7i76e
09 Apr 2017 08:36 #91075
I'm using this one because I had it and it came with linux drivers
www.asus.com/au/Networking/USBN10_NANO/
A couple of years ago when I installed Wheezy ISO on a 32 bit machine, I compiled the source and it just worked. More recently I could not install it but I found some instructions on line that let me install it. I think its supported natively in Mint which is what I'm running.
There are probably better options.
Replied by rodw on topic new system with 7i76e
can you recomend me a USB wifi dongle who run without problems under linux?
09 Apr 2017 08:39 #91076
And if you have not found it, the connection sheet on this thread is very very useful.
forum.linuxcnc.org/27-driver-boards/3191...76e-connection-sheet
09 Apr 2017 20:11 #91095
by trilobyte
Replied by trilobyte on topic new system with 7i76e
i used pncconf to create a setup.
after giving the pc a fix ip adress (192.168.1.120) and using a working ethernetcable i was able to start linuxcnc!
09 Apr 2017 20:27 - 09 Apr 2017 20:29 #91097
See, Its easier than you think!
Here are some instructions from Big JohnT about setting up the network.
mesaus.com/info/7i76e.txt
Depending on the IP address range of your network, you might need to change the IP address set by PNCCONF (in your HAL file) so then you can run it on the 10. range.
The network restart shown there does not work with Mint and the correct ones are listed (by me) early in the Mint Tutorial thread. There are also some hal parameters to enable the MPG inputs. I think its detailed on the connection sheet I linked to.
Last edit: 09 Apr 2017 20:29 by rodw.
Time to create page: 0.364 seconds
