Ethernet Boards
10 Apr 2017 18:50 #91140
by tjones
Ethernet Boards was created by tjones
Hi All,
I am looking to replace my standard BOB with one of the Mesa boards. I have used the 5I25 with 7I77 before and it works great. I am looking for a board for my stepper system with a servo spindle. The servo running the spindle is controlled through an analog +/-10v signal, it functions just like a VFD in it's "speed mode", and the encoder feedback is 5v. In terms of I/O the 7i96 has all the I/O and capability that I need. However one of my main concerns is that it needs to support the +/-10v analog for the spindle. It doesn't directly say it has the option in the manual, so I would like to confirm it. Also when running one of these Ethernet boards (7i96 or 7i76E) can I use the standard StepConf to configure everything? Thus far I haven't had to do any major HAL or INI file programming, just minor things like the root folder that opens when loading a NC file or adjusting initial jog speed and I would like to keep that type of programming to a minimum. Also do I need an special Ethernet port on my computer or will the standard port work.
Thanks,
Tosh
Thanks,
Tosh
10 Apr 2017 19:16 #91143
Replied by PCW on topic Ethernet Boards
The 7I96 has no Analog spindle control, so a 7I76E may be a better choice here
(Also the 7I96 is very new so not as well supported)
10 Apr 2017 20:54 #91147
by tjones
Replied by tjones on topic Ethernet Boards
Thanks, that is very helpful information. Do you know if the 7i76e is supported through the StepConf? I know the regular 7i76+5i25 is supported through StepConf but it is currently out of stock and I would like to purchase soon.
11 Apr 2017 00:28 #91159
Both the 7I76 and the 7I76E are supported by pncconf
we should have more 7I76s by the end of this week
Time to create page: 0.184 seconds
