5i22-1
19 Apr 2017 20:34 #91674
by billykid
Hi, I made a lathe configuration with 5i23 working with svst2_4_7i47.
To have more input I bought a 5i22-1 to use instead of 5i23.
The error is this: hm2_5i22.0: firmware: requesting hm2 / 5i22-1 / SVST2_4_7I47.BIT
hm2 / hm2_5i22.0: IDROM IOPorts is 4 but MD IOPort NumInstances is 3, inconsistent firmware, aborting driver load
I had tried with pnconf and seemed to go with the same driver.
what am I doing wrong ?
Thanks in advance
Mauro
Thanks in advance
Mauro
19 Apr 2017 21:41 #91677
Looks like a bad bitfile (probably a copy paste error in the pinout file)
The pinout source was fixed fairly recently so likely had an error
Here's a new bitfile:
freeby.mesanet.com/5i22_1_svst2_4_7i47.bit
That should fix the issue (you probably have to rename it and install it in the correct place
The following user(s) said Thank You: billykid
Time to create page: 0.062 seconds
