Mesa 7i96 Ethernet board
21 Jul 2017 00:30 #96199
I have no idea what you mean by this.
What on earth have you done?
Replied by andypugh on topic Mesa 7i96 Ethernet board
LOL, I don't get it either. I put your setup file and the data strobe file in a m100 ,m101,m105 command and they work pretty good. )
- microsprintbuilder
- Thank you received: 4
21 Jul 2017 00:36 #96201
by microsprintbuilder
Replied by microsprintbuilder on topic Mesa 7i96 Ethernet board
Sorry for the confusion, I need to walk away from this for a hours. What I was saying is before I started this comp i was use the setup and on off scripts in aux m codes and ran them that way. It works but I was wanting something more reliable.
21 Jul 2017 19:14 #96241
Got the machine computer up and running. raw_writer.comp works!!!!! . only thing I that might need addressed is on startup all the outs come on. It's just a flash so until I get the machine all hooked up I won't know if it's even a issue. I must have some real issues with my laptop to not get this to work there. Anyway,Thanks again.
30 Jan 2018 19:51 #105206
by Psykhon
Replied by Psykhon on topic Mesa 7i96 Ethernet board
Are the isolated outputs working now?
30 Jan 2018 20:29 - 30 Jan 2018 20:57 #105208
Replied by PCW on topic Mesa 7i96 Ethernet board
Yes, there is (very new) support in the 7i96 branch this should be merged with master soon
if you want to try it now you can build from source (select the 7I96 branch)
BTW, here are the 7I96 output hal pins:
23 bit IN FALSE hm2_7i96.0.ssr.00.out-00
23 bit IN FALSE hm2_7i96.0.ssr.00.out-01
23 bit IN FALSE hm2_7i96.0.ssr.00.out-02
23 bit IN FALSE hm2_7i96.0.ssr.00.out-03
23 bit IN FALSE hm2_7i96.0.ssr.00.out-04
23 bit IN FALSE hm2_7i96.0.ssr.00.out-05
Last edit: 30 Jan 2018 20:57 by PCW.
10 Feb 2018 02:07 #105680
by blazini36
Replied by blazini36 on topic Mesa 7i96 Ethernet board
Not to threadjack, but I stumbled across this thread as I was looking for some info on the 7I96 before I purchase one. I couldn't really follow this whole thread but is there something not quite ready yet with the 7I96? I have a 7i76e running on a different project without issue but the 7I76e is overkill for that particular machine I/O wise. I was going to move the 7I76e over to the Milling machine I just picked up to convert to CNC and swap a 7I96 into the other machine. Am I better off just sticking to a 7i76e for both?
10 Feb 2018 02:28 #105681
Yes, if you want the high current ( SSR ) outputs to work you either have to install the hal hacks shown earlier in this thread
or use the 7I96 branch of master
So if you don't mind using master and compiling the 7I96 branch the 7I96 works fine, otherwise
there's some rather ugly hal hackery needed to make the hi current outputs work
10 Feb 2018 02:45 #105682
And if you don't need the SSR outputs?
10 Feb 2018 02:56 #105683
by blazini36
Low current outputs (350ma like the 7i76e) would be fine for now if it just works. I didn't realize the outputs on the 7i96 were different/high current. Looking at the manual I don't quite understand how they are laid out. They are labeled as out+/-, I assume this means they can either sink or source but I don't see a field power terminal that is common to the outputs. Or am I misunderstanding the usage?
10 Feb 2018 04:21 - 10 Feb 2018 04:55 #105688
The are individual switch (SSR) outputs (no common) so can sink or source
They will work on any DC voltage up to 48VDC and switch up to 2A
Inductive loads require a flyback diode
Last edit: 10 Feb 2018 04:55 by PCW.
Time to create page: 0.176 seconds
