- Hardware & Machines
- Driver Boards
- 7i80 + 7i77 config: Pin '7i80.0.7i77.0.0.output-000' does not exist
15 May 2017 19:34 #93231
by Shu
Hi, I'm trying to mate a 7i77 to a 7i80.
12V field power is applied, jumper for field power is in default position. All the other jumpers also in default position, except the necessary ones to have 5V supplied via db25 male-male cable (1:1 cable shielded) and the IP select jumper on the 7i80 to read the IP address from the EEPROM.
Best,
Shu
Log:
.hal file:
Best,
Shu
Log:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/as/linuxcnc/configs/justinbieber'
Machine configuration file is 'justinbieber.ini'
INIFILE=/home/as/linuxcnc/configs/justinbieber/justinbieber.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./justinbieber.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.42.121: Hardware address: 00:60:1b:10:00:12
hm2_eth: discovered 7I80DB-25
hm2/hm2_7i80.0: Smart Serial Firmware Version 43
Board hm2_7i80.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i80.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i80.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i80.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i80.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i80.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i80.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_7i80.0: 68 I/O Pins used:
hm2/hm2_7i80.0: IO Pin 000 (J2-01): IOPort
hm2/hm2_7i80.0: IO Pin 001 (J2-14): IOPort
hm2/hm2_7i80.0: IO Pin 002 (J2-02): IOPort
hm2/hm2_7i80.0: IO Pin 003 (J2-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i80.0: IO Pin 004 (J2-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i80.0: IO Pin 005 (J2-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i80.0: IO Pin 006 (J2-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i80.0: IO Pin 007 (J2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i80.0: IO Pin 008 (J2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 009 (J2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 010 (J2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 011 (J2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 012 (J2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 013 (J2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 014 (J2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 015 (J2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 016 (J2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 017 (J3-01): IOPort
hm2/hm2_7i80.0: IO Pin 018 (J3-14): IOPort
hm2/hm2_7i80.0: IO Pin 019 (J3-02): IOPort
hm2/hm2_7i80.0: IO Pin 020 (J3-15): IOPort
hm2/hm2_7i80.0: IO Pin 021 (J3-03): IOPort
hm2/hm2_7i80.0: IO Pin 022 (J3-16): IOPort
hm2/hm2_7i80.0: IO Pin 023 (J3-04): IOPort
hm2/hm2_7i80.0: IO Pin 024 (J3-17): IOPort
hm2/hm2_7i80.0: IO Pin 025 (J3-05): IOPort
hm2/hm2_7i80.0: IO Pin 026 (J3-06): IOPort
hm2/hm2_7i80.0: IO Pin 027 (J3-07): IOPort
hm2/hm2_7i80.0: IO Pin 028 (J3-08): IOPort
hm2/hm2_7i80.0: IO Pin 029 (J3-09): IOPort
hm2/hm2_7i80.0: IO Pin 030 (J3-10): IOPort
hm2/hm2_7i80.0: IO Pin 031 (J3-11): IOPort
hm2/hm2_7i80.0: IO Pin 032 (J3-12): IOPort
hm2/hm2_7i80.0: IO Pin 033 (J3-13): IOPort
hm2/hm2_7i80.0: IO Pin 034 (J4-01): IOPort
hm2/hm2_7i80.0: IO Pin 035 (J4-14): IOPort
hm2/hm2_7i80.0: IO Pin 036 (J4-02): IOPort
hm2/hm2_7i80.0: IO Pin 037 (J4-15): IOPort
hm2/hm2_7i80.0: IO Pin 038 (J4-03): IOPort
hm2/hm2_7i80.0: IO Pin 039 (J4-16): IOPort
hm2/hm2_7i80.0: IO Pin 040 (J4-04): IOPort
hm2/hm2_7i80.0: IO Pin 041 (J4-17): IOPort
hm2/hm2_7i80.0: IO Pin 042 (J4-05): IOPort
hm2/hm2_7i80.0: IO Pin 043 (J4-06): IOPort
hm2/hm2_7i80.0: IO Pin 044 (J4-07): IOPort
hm2/hm2_7i80.0: IO Pin 045 (J4-08): IOPort
hm2/hm2_7i80.0: IO Pin 046 (J4-09): IOPort
hm2/hm2_7i80.0: IO Pin 047 (J4-10): IOPort
hm2/hm2_7i80.0: IO Pin 048 (J4-11): IOPort
hm2/hm2_7i80.0: IO Pin 049 (J4-12): IOPort
hm2/hm2_7i80.0: IO Pin 050 (J4-13): IOPort
hm2/hm2_7i80.0: IO Pin 051 (J5-01): IOPort
hm2/hm2_7i80.0: IO Pin 052 (J5-14): IOPort
hm2/hm2_7i80.0: IO Pin 053 (J5-02): IOPort
hm2/hm2_7i80.0: IO Pin 054 (J5-15): IOPort
hm2/hm2_7i80.0: IO Pin 055 (J5-03): IOPort
hm2/hm2_7i80.0: IO Pin 056 (J5-16): IOPort
hm2/hm2_7i80.0: IO Pin 057 (J5-04): IOPort
hm2/hm2_7i80.0: IO Pin 058 (J5-17): IOPort
hm2/hm2_7i80.0: IO Pin 059 (J5-05): IOPort
hm2/hm2_7i80.0: IO Pin 060 (J5-06): IOPort
hm2/hm2_7i80.0: IO Pin 061 (J5-07): IOPort
hm2/hm2_7i80.0: IO Pin 062 (J5-08): IOPort
hm2/hm2_7i80.0: IO Pin 063 (J5-09): IOPort
hm2/hm2_7i80.0: IO Pin 064 (J5-10): IOPort
hm2/hm2_7i80.0: IO Pin 065 (J5-11): IOPort
hm2/hm2_7i80.0: IO Pin 066 (J5-12): IOPort
hm2/hm2_7i80.0: IO Pin 067 (J5-13): IOPort
hm2/hm2_7i80.0: registered
Running HAL shutdown script
Killing task linuxcncsvr, PID=7527
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./justinbieber.hal:25: Pin '7i80.0.7i77.0.0.output-000' does not exist
7527
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
.hal file:
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
setp hm2_[HOSTMOT2](BOARD).0.watchdog.timeout_ns 25000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_[HOSTMOT2](BOARD).0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
# external output signals
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled [HOSTMOT2](BOARD).0.7i77.0.0.output-000
# --- SPINDLE-ON ---
net spindle-on [HOSTMOT2](BOARD).0.7i77.0.0.output-01
# --- COOLANT-FLOOD ---
net coolant-flood [HOSTMOT2](BOARD).0.7i77.0.0.output-02
# --- COOLANT-MIST ---
net coolant-mist [HOSTMOT2](BOARD).0.7i77.0.0.output-03
# --- ESTOP-OUT ---
net estop-out [HOSTMOT2](BOARD).0.7i77.0.0.output-04
# external input signals
# --- ABORT ---
net abort <= [HOSTMOT2](BOARD).0.7i77.0.0.input-00
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net x-output => [HOSTMOT2](BOARD).0.7i77.0.1.analogout0
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable [HOSTMOT2](BOARD).0.7i77.0.1.analogena
setp [HOSTMOT2](BOARD).0.encoder.01.counter-mode 0
setp [HOSTMOT2](BOARD).0.encoder.01.filter 1
setp [HOSTMOT2](BOARD).0.encoder.01.index-invert 0
setp [HOSTMOT2](BOARD).0.encoder.01.index-mask 0
setp [HOSTMOT2](BOARD).0.encoder.01.index-mask-invert 0
setp [HOSTMOT2](BOARD).0.encoder.01.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= [HOSTMOT2](BOARD).0.encoder.01.position
net x-vel-fb <= [HOSTMOT2](BOARD).0.encoder.01.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> [HOSTMOT2](BOARD).0.encoder.01.index-enable
net x-pos-rawcounts <= [HOSTMOT2](BOARD).0.encoder.01.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT
net y-output => [HOSTMOT2](BOARD).0.7i77.0.1.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
setp [HOSTMOT2](BOARD).0.encoder.03.counter-mode 0
setp [HOSTMOT2](BOARD).0.encoder.03.filter 1
setp [HOSTMOT2](BOARD).0.encoder.03.index-invert 0
setp [HOSTMOT2](BOARD).0.encoder.03.index-mask 0
setp [HOSTMOT2](BOARD).0.encoder.03.index-mask-invert 0
setp [HOSTMOT2](BOARD).0.encoder.03.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= [HOSTMOT2](BOARD).0.encoder.03.position
net y-vel-fb <= [HOSTMOT2](BOARD).0.encoder.03.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> [HOSTMOT2](BOARD).0.encoder.03.index-enable
net y-pos-rawcounts <= [HOSTMOT2](BOARD).0.encoder.03.rawcounts
net y-home-sw => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => [HOSTMOT2](BOARD).0.7i77.0.1.analogout2
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
setp [HOSTMOT2](BOARD).0.encoder.05.counter-mode 0
setp [HOSTMOT2](BOARD).0.encoder.05.filter 1
setp [HOSTMOT2](BOARD).0.encoder.05.index-invert 0
setp [HOSTMOT2](BOARD).0.encoder.05.index-mask 0
setp [HOSTMOT2](BOARD).0.encoder.05.index-mask-invert 0
setp [HOSTMOT2](BOARD).0.encoder.05.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= [HOSTMOT2](BOARD).0.encoder.05.position
net z-vel-fb <= [HOSTMOT2](BOARD).0.encoder.05.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> [HOSTMOT2](BOARD).0.encoder.05.index-enable
net z-pos-rawcounts <= [HOSTMOT2](BOARD).0.encoder.05.rawcounts
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout3-scalemax [SPINDLE_9]OUTPUT_SCALE
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout3-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp [HOSTMOT2](BOARD).0.7i77.0.1.analogout3-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
net spindle-vel-cmd-rpm-abs => [HOSTMOT2](BOARD).0.7i77.0.1.analogout3
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
15 May 2017 19:45 #93232
Replied by PCW on topic 7i80 + 7i77 config: Pin '7i80.0.7i77.0.0.output-000' does not exist
Too many zeros in 7i80.0.7i77.0.0.output-000
The following user(s) said Thank You: Shu
15 May 2017 19:55 #93235
by Shu
Also tried
All to no avail. Can you give me an example?
Thanks,
Shu
Replied by Shu on topic 7i80 + 7i77 config: Pin '7i80.0.7i77.0.0.output-000' does not exist
./justinbieber.hal:21: Pin '7i80.0.7i77.0.0.output-00' does not exist
Also tried
net machine-is-enabled [HOSTMOT2](BOARD).0.7i77.0.1.output-00
net machine-is-enabled [HOSTMOT2](BOARD).0.7i77.0.output-00
net machine-is-enabled [HOSTMOT2](BOARD).7i77.0.0.output-00
Thanks,
Shu
15 May 2017 20:04 #93236
by Shu
Found the mistake! I was missing the hm2_ in front
Shu
Shu
15 May 2017 20:05 #93237
hm2_7i80.0.7i77.0.0.output-00 is correct
- Driver Boards
Time to create page: 0.121 seconds
