Two Mesa 5I20
31 May 2017 06:32 #93867
by dirk61
Two Mesa 5I20 was created by dirk61
Hello
Would like to use two 5I20.
Can I choose in the PNCONF or what I have to write in the HAL itself the card?
Does anyone have an example?
MfG Dirk
MfG Dirk
31 May 2017 12:08 #93877
Replied by andypugh on topic Two Mesa 5I20
You can use as many PCI cards as you have PCI slots. They will have pins with names like hm2_5i20.0 and hm2_5i20.1
But, why are you using the 5i20? There are cheaper cards from Mesa with the same capabilities. (the 5i24, for example)
31 May 2017 12:11 #93879
linuxcnc.org/docs/2.7/html/config/pnccon..._machine_information
PnCConf appears to understand how to configure 2 cards. If you need more than 2 then you would need to hand-edit.
Why do you need 2 cards? A single 5i20 (or 5i23, 5i24..) can handle 1152 IO pins using the smart-serial daughter cards.
31 May 2017 13:37 #93885
by dirk61
Replied by dirk61 on topic Two Mesa 5I20
Hello
Have a 7I33TA and two 7I37 turn it is not enough I / O for my machine
31 May 2017 13:57 #93887
You could swap one 7i37 for a 7i44 + any combination of up to 8 of these boards:
store.mesanet.com/index.php?route=product/category&path=83_88
31 May 2017 14:00 #93888
If you want to use more 7i37 cards, it would be sensible to use a 5i24 rather than another 5i20, in any case.
01 Jun 2017 05:08 - 01 Jun 2017 05:21 #93914
by dirk61
Hello
For the combination with the 5I24 with a 7I48 + (3X 7I37TA) + (7I52S) what I still need for it?
Last edit: 01 Jun 2017 05:21 by dirk61.
01 Jun 2017 13:39 #93929
Sorry, I am confused now.
Can you tell us what hardware you already have and how many servo channels and IO pins you need?
02 Jun 2017 04:23 - 02 Jun 2017 04:24 #93990
by dirk61
So far I have a 5I20 to 2X7I37TA and 1X7I48
The IO pins are exhausted
There is also a tool changer and a fourth axis.
Whether I build the two áls servo system or with steppers I'm still hesitant ............
Mfg Dirk
Mfg Dirk
Last edit: 02 Jun 2017 04:24 by dirk61.
02 Jun 2017 11:54 #93997
I see two cost-effective ways to add more IO.
1) Add a 5i24 and another 7i37TA = $198 for 8 outputs and 16 inputs
2) Swap an existing 7i37TA for a 7i44 and a 7i84. That is $148 for a net gain of 16 inputs and 8 outputs. (and another $79 gets you 16 more outputs and 32 inputs)
But: I think that the 7i37TA IO can be used for step-generation and encoder counting, whilst the 7i84 (and other smart-serial cards) can not. Though the 7i84 has two on-board MPG counters.
Time to create page: 0.129 seconds
