7i33 spindle
29 Jun 2017 20:08 #95188
by billykid
Replied by billykid on topic 7i33 spindle
Thanks Andy,
I added a couple of "or2" and now i have gpio 19 and pwmgen-enable on
I will have to adjust something because now in the orient half-way forward and half turn back faster and faster without stopping.
Tomorrow I feel better ..
The following user(s) said Thank You: massimodamassa
29 Jun 2017 20:20 #95189
Replied by andypugh on topic 7i33 spindle
Probably a lot too much I gain, or possibly too much P gain.
30 Jun 2017 08:46 - 30 Jun 2017 08:49 #95201
by billykid
Thanks Andy,
I did not realize that the motor and inverter I'm testing with does not work at very low speeds, so it accumulates error then changes to the minimum voltage to run.
the brushless AC fanuc where it goes will surely behave well.
I can not understand why it does not use the encoder index ... it needs proximity for homing spindle ?
Last edit: 30 Jun 2017 08:49 by billykid.
02 Jul 2017 15:39 #95280
You probably want to use the index once at start-up to zero the encoder to a fixed position, but you won't need to do it again. (But, if there is a risk that the encoder loses counts at high speed, then you could zero to index again)
To make a VFD work with a PID you probably need a gain curve to modify the output of the PID. I would use a lincurve component set up something likeAssuming that the VFD starts to move at 1V commanded.
in out
0 0
.01 1
10 10
The following user(s) said Thank You: billykid
03 Jul 2017 10:29 #95298
by billykid
Thanks Andy,
I used "lincurve" and set the pid, now working much better.
The signal "is oriented" is missing and does not stop the cycle but I'm trying.
03 Jul 2017 12:25 #95301
motion.spindle-is-oriented should be there:
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
Time to create page: 0.108 seconds
