MESA Card Recommendation
22 Aug 2017 07:34 #97859
by remrendes
Replied by remrendes on topic MESA Card Recommendation
Or not!? For 3000rpm I need 12MHz with the 1000ppr encoder.
The following user(s) said Thank You: Chathuranga555
22 Aug 2017 13:31 #97870
Replied by PCW on topic MESA Card Recommendation
3000 RPM with a 1000 PPR encoder (4000 quadrature counts/rev) is a 200 KHz count rate
(50 RPS * 4000)
(50 RPS * 4000)
22 Aug 2017 13:57 - 22 Aug 2017 13:58 #97874
by remrendes
Ohh, yes, I calculated in minutes. Anyway, I can use the ethernet type with a laptop as well.
Last edit: 22 Aug 2017 13:58 by remrendes.
22 Aug 2017 15:41 #97880
You should be aware that laptops in general do not make good LinuxCNC hosts
This is because they very often have power management hardware/software that cannot be disabled
and that causes large latencies. Some Laptops may be OK or at least OK until you change the backlight brightness
or change from line to battery power etc etc
- Chathuranga555
- Banned
02 May 2019 05:00 #132483
by Chathuranga555
Replied by Chathuranga555 on topic MESA Card Recommendation
hi guys,
I am a beginner of LINUXCNC and there is a 3 Axis wood router machine with 4 spindle drivers and large number of drilling, routing tools and hundreds of I/O. And the existing controller is not functioning, so my boss asked me to try to replace the controller with linux cnc & mesa card. What card is the best solution for my requirement.
I have mesa 5i24 & 2x 7i48 cards. Are they suitable for my requirement?
Please help me for these 2 questions.
02 May 2019 06:11 #132491
by pl7i92
Replied by pl7i92 on topic MESA Card Recommendation
Hi
as the Mashine seams Servo 7i48 you are fine
you can go with your mesa cards they will work as you think
the 5i24 and 7i48 can drive your spindles as well
you are in good setup maybe you shoudt consider a 7i34 for the RS485 Modebus comunication to the Spindles
as well as a 7i73 or a 7i42 for the IO you need
- Chathuranga555
- Banned
02 May 2019 10:44 #132508
by Chathuranga555
Thank you for your help.
Could you please let me know how to run my spindles with 7i48 card.
Hi
02 May 2019 11:29 #132515
by tecno
Replied by tecno on topic MESA Card Recommendation
Assuming your servo drivers are analog ±10V controlled you should be OK.
02 May 2019 12:14 #132521
by pl7i92
the 7i48 you got 2 of them got enoph analog out to drive the spindles as i count 12AXIS servos available
so simply use more then 1 pidloop to get them run
you need 3/4 Analog for your Woodrooter so 2/3 Spindles on the First 7i48
then you got 6 more spindle to control on the second 7i48
02 May 2019 12:54 #132530
Typically with the system you have you would use a 7I37TA for general purpose I/O
As techno mentioned, the 7I48s are for interfacing with analog +- 10V servos or
+-10V,0 --> 10V spindles
Time to create page: 0.588 seconds
