7i76 spindle index
08 Jul 2017 21:19 #95516
by Michael
7i76 spindle index was created by Michael
I have a servo motor as a spindle. It is run off the analog spin out on the 7i76. The motor is geared 2 to 1 and I have the motor encoder is attached to ENCA +/- and ENCB +/- with jumpers W4,5,6 in the right hand position with the conversion for gearing handled in my ini file.
In order to do tapping I need to get a spindle index signal off the spindle itself and plan to use a photo interruptor on a slotted disk. This will obviously be a single ended signal to IDX+. Will this be an issue since the encoder is differential or will I need to use the motor encoder in single ended mode only?
08 Jul 2017 22:19 #95519
Replied by PCW on topic 7i76 spindle index
The single-ended/differential mode select jumpers are separate for A,B,IDX so you can jumper the encoder A/B
lines for differential and the index for single ended if desired.
W6 = A MODE
W5 = B MODE
W4 = IDX MODE
W6 = A MODE
W5 = B MODE
W4 = IDX MODE
08 Jul 2017 22:29 #95520
by Michael
Replied by Michael on topic 7i76 spindle index
That is what I assumed but I would have figured they were the other way around W4 for A etc. Is there any draw back to using a single ended index for tapping? It will not be affected by the scaling of the rest of the encoder correct?
Thank you for the reply.
Time to create page: 0.095 seconds
