Mesa 7i76e - Joint 0/2 following error
- Online
- Thank you received: 1369
18 Jul 2017 17:48 - 18 Jul 2017 17:48 #96011
Replied by Todd Zuercher on topic Mesa 7i76e - Joint 0/2 following error
Your story makes me think of two guys riding in a pickup see an animal laying in the ditch, they stop. One says to the other "is it dead." "Don't know." "Poke it with a stick." He gets out of the truck with a baseball bat and beats it in the head a few times. "Yep, its dead."
Last edit: 18 Jul 2017 17:48 by Todd Zuercher.
18 Jul 2017 21:36 #96024
Replied by rodw on topic Mesa 7i76e - Joint 0/2 following error
It sounds like your cousin uses a particularly brutal form of electronics. Nonetheless a baseball wielding cousin could be handy to call on at times....
It sounds like you are on the right track. If you still get latency errors, let us know. I remember playing around with a number of BIOS Settings and running latency tests until I settled on a working config with the least latency.
Once you are happy it is working reliably, you may wish to add a USB wifi dongle if you need to connect it to your network and the internet.
- JackBerkhout
- Topic Author
18 Jul 2017 22:20 - 18 Jul 2017 22:21 #96026
by JackBerkhout
Replied by JackBerkhout on topic Mesa 7i76e - Joint 0/2 following error
Tonight, after disabling the WiFi with the command "nmcli wifi off", I haven't seen any errors, yet.
It appears to make a difference, even though, I had not configured an access point, when it was still enabled.
Didn't know it could harm that way...
I'm going to sleep...
Last edit: 18 Jul 2017 22:21 by JackBerkhout.
- JackBerkhout
- Topic Author
20 Jul 2017 18:21 #96158
by JackBerkhout
Disabling the unused WiFi, that didn't improve to much, after all, I guess.
So I need a more powerful barebone.
This looks very nice (I need a VGA connector), but not cheap.
www.aliexpress.com/item/Hystou-Core-i5-M...ICS/32804101413.html
20 Jul 2017 18:28 #96159
Replied by andypugh on topic Mesa 7i76e - Joint 0/2 following error
Unfortunately, "more powerful" doesn't always mean "lower latency"
I don't have a 7i76E so can't give any specific recommendations, though.
The following user(s) said Thank You: JackBerkhout
20 Jul 2017 18:45 #96162
Replied by PCW on topic Mesa 7i76e - Joint 0/2 following error
Before you give up on your current CPU, What OS/ kernel are you using?
(uname -a will print the kernel version)
If you are using the years old 3.2 Preempt-RT kernel you may do better with a newer kernel
(Trying the new Debian Stretch ISO + 4.9 Preempt-RT kernel is at least worth a try)
www.linuxcnc.org/testing-stretch-rtpreempt/
- JackBerkhout
- Topic Author
20 Jul 2017 19:09 #96166
by JackBerkhout
Hi Andy,
true!
Hi PCW,
uname -a
Linux LinuxCNC 3.2.0-4-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.89-2 i686 GNU/Linux
Thank you for checking!
Regards,
Jack.
true!
Hi PCW,
uname -a
Regards,
Jack.
20 Jul 2017 20:47 #96176
I would try what PCW suggests. If you buy new hardware, you probably will need to use a more modern build of Linux to get the driver support so you might as well practice on your existing hardware!
I have not got any direct experience but when I was looking for hardware, Celeron based chipsets were recommended. PCW will know more but something like a N3160 cpu which will save you some money. Your Chinese friends will have one....
- JackBerkhout
- Topic Author
20 Jul 2017 22:17 #96186
by JackBerkhout
Hi Rod,
I found this refurbished PC, not expensive, but it may not be a Celeron.
www.alpha-shop.nl/hp-dc7900-core2duo-250gb-4gb.html
This was the cheapest, though.
Regards,
Jack.
Regards,
Jack.
21 Jul 2017 00:32 #96200
Jack, sorry I can't really advise you on hardware. There are a few Core2's listed here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
Hi Rod,
Regards,
Jack.
Time to create page: 0.320 seconds
