Mesa 7i43. Error loading configuration.
01 Feb 2011 11:57 #6915 by andradela
root@luiz-desktop:/home/luiz# sudo apt-get install emc2-firmware
Lendo listas de pacotes... Pronto
Construindo árvore de dependências
Lendo informação de estado... Pronto
Nota, selecionando hostmot2-firmware-all ao invés de emc2-firmware
hostmot2-firmware-all já é a versão mais nova.
0 pacotes atualizados, 0 pacotes novos instalados, 0 a serem removidos e 14 não atualizados.
01 Feb 2011 12:57 - 01 Feb 2011 12:58 #6917 by andradela
Hello
After some attempts, some commands that I find, now the samples hm2-steppers not works more, what are this wrongs?
What I need to do to fix it?
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/luiz/emc2/configs/hm2-stepper'
Machine configuration file is '7i43-big.ini'
INIFILE=/home/luiz/emc2/configs/hm2-stepper/7i43-big.ini
PARAMETER_FILE=hm2-stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1546
Cleanup done
Debug file information:
module_helper is not setuid root
1546
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.2 present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x3fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CEFFF write-protect
[ 0.000000] CF000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009f800 (usable)
[ 0.000000] modified: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] modified: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
[ 0.000000] modified: 000000003fff3000 - 0000000040000000 (ACPI data)
[ 0.000000] modified: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 2f8d1000 - 30033fc9
[ 0.000000] ACPI: RSDP 000f70d0 00014 (v00 AWARD )
[ 0.000000] ACPI: RSDT 3fff3000 0002C (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 3fff3040 00074 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 3fff30c0 039A1 (v01 AWARD AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 3fff0000 00040
[ 0.000000] ACPI: APIC 3fff6a80 00068 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [002f8d1000 - 0030033fc9] RAMDISK ==> [002f8d1000 - 0030033fc9]
[ 0.000000] #5 [000009f800 - 0000100000] BIOS reserved ==> [000009f800 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b406e] BRK ==> [00008b1000 - 00008b406e]
[ 0.000000] #7 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] found SMP MP-table at [c00f56c0] f56c0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003fff0
[ 0.000000] On node 0 totalpages: 262015
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 272 pages used for memmap
[ 0.000000] HighMem zone: 34530 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 20, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 dfl dfl)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bec00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1c00000 s74936 r0 d23368 u2097152
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u2097152 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259967
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=31f286c5-b1e7-4fcd-8f1d-5fe2b1efb825 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5242240 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003fff0)
[ 0.000000] Memory: 1017740k/1048512k available (4539k kernel code, 29784k reserved, 1928k data, 620k init, 139208k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:424
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2390.792 MHz processor.
[ 0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 4781.58 BogoMIPS (lpj=9563168)
[ 0.008040] Security Framework initialized
[ 0.008075] AppArmor: AppArmor initialized
[ 0.008089] Mount-cache hash table entries: 512
[ 0.008324] Initializing cgroup subsys ns
[ 0.008333] Initializing cgroup subsys cpuacct
[ 0.008342] Initializing cgroup subsys memory
[ 0.008356] Initializing cgroup subsys devices
[ 0.008361] Initializing cgroup subsys freezer
[ 0.008366] Initializing cgroup subsys net_cls
[ 0.008406] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008413] CPU: L2 cache: 512K
[ 0.008417] CPU: Hyper-Threading is disabled
[ 0.008424] mce: CPU supports 4 MCE banks
[ 0.008439] CPU0: Thermal monitoring enabled (TM1)
[ 0.008456] Performance Events: no PMU driver, software events only.
[ 0.008468] Checking 'hlt' instruction... OK.
[ 0.025316] SMP alternatives: switching to UP code
[ 0.038997] ACPI: Core revision 20090903
[ 0.052017] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.052028] ftrace: allocating 21003 entries in 42 pages
[ 0.068789] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.069070] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.072001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.072001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.072001] ..... (found apic 0 pin 2) ...
[ 0.112497] ....... works.
[ 0.112501] CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz stepping 09
[ 0.116001] Brought up 1 CPUs
[ 0.116001] Total of 1 processors activated (4781.58 BogoMIPS).
[ 0.116001] CPU0 attaching NULL sched-domain.
[ 0.116001] devtmpfs: initialized
[ 0.116001] regulator: core version 0.5
[ 0.116001] NET: Registered protocol family 16
[ 0.116001] EISA bus registered
[ 0.116001] ACPI: bus type pci registered
[ 0.124914] PCI: PCI BIOS revision 2.10 entry at 0xfb340, last bus=1
[ 0.124919] PCI: Using configuration type 1 for base access
[ 0.126108] bio: create slab <bio-0> at 0
[ 0.126897] ACPI: EC: Look up EC in DSDT
[ 0.135083] ACPI: Interpreter enabled
[ 0.135088] ACPI: (supports S0 S5)
[ 0.135106] ACPI: Using IOAPIC for interrupt routing
[ 0.141540] ACPI: No dock devices found.
[ 0.141692] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.141761] pci 0000:00:00.0: reg 10 32bit mmio: [0xe0000000-0xe7ffffff]
[ 0.141960] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.142025] pci 0000:00:02.1: reg 20 io port: [0x10c0-0x10df]
[ 0.142095] pci 0000:00:02.5: reg 10 io port: [0x1f0-0x1f7]
[ 0.142106] pci 0000:00:02.5: reg 14 io port: [0x3f4-0x3f7]
[ 0.142115] pci 0000:00:02.5: reg 18 io port: [0x170-0x177]
[ 0.142125] pci 0000:00:02.5: reg 1c io port: [0x374-0x377]
[ 0.142135] pci 0000:00:02.5: reg 20 io port: [0x4000-0x400f]
[ 0.142176] pci 0000:00:02.5: supports D1 D2
[ 0.142179] pci 0000:00:02.5: PME# supported from D3cold
[ 0.142186] pci 0000:00:02.5: PME# disabled
[ 0.142235] pci 0000:00:02.6: reg 10 io port: [0xe000-0xe0ff]
[ 0.142246] pci 0000:00:02.6: reg 14 io port: [0xe100-0xe17f]
[ 0.142306] pci 0000:00:02.6: supports D1 D2
[ 0.142309] pci 0000:00:02.6: PME# supported from D3hot D3cold
[ 0.142315] pci 0000:00:02.6: PME# disabled
[ 0.142363] pci 0000:00:02.7: reg 10 io port: [0xe200-0xe2ff]
[ 0.142374] pci 0000:00:02.7: reg 14 io port: [0xe300-0xe37f]
[ 0.142433] pci 0000:00:02.7: supports D1 D2
[ 0.142436] pci 0000:00:02.7: PME# supported from D3hot D3cold
[ 0.142443] pci 0000:00:02.7: PME# disabled
[ 0.142476] pci 0000:00:03.0: reg 10 32bit mmio: [0xea023000-0xea023fff]
[ 0.142550] pci 0000:00:03.1: reg 10 32bit mmio: [0xea020000-0xea020fff]
[ 0.142644] pci 0000:00:03.3: reg 10 32bit mmio: [0xea021000-0xea021fff]
[ 0.142709] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[ 0.142715] pci 0000:00:03.3: PME# disabled
[ 0.142770] pci 0000:00:04.0: reg 10 io port: [0xe400-0xe4ff]
[ 0.142781] pci 0000:00:04.0: reg 14 32bit mmio: [0xea022000-0xea022fff]
[ 0.142818] pci 0000:00:04.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.142845] pci 0000:00:04.0: supports D1 D2
[ 0.142848] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.142855] pci 0000:00:04.0: PME# disabled
[ 0.142963] pci 0000:01:00.0: reg 10 32bit mmio: [0xe8000000-0xe8ffffff]
[ 0.142972] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.143001] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.143084] pci 0000:00:01.0: bridge 32bit mmio: [0xe8000000-0xe9ffffff]
[ 0.143092] pci 0000:00:01.0: bridge 32bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.143104] pci_bus 0000:00: on NUMA node 0
[ 0.143111] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.169498] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.169659] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.169815] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.169971] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.170125] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.170281] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.170434] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.170590] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 9 10 11 12 14 15)
[ 0.170778] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.170784] vgaarb: loaded
[ 0.170986] SCSI subsystem initialized
[ 0.171094] libata version 3.00 loaded.
[ 0.171205] usbcore: registered new interface driver usbfs
[ 0.171226] usbcore: registered new interface driver hub
[ 0.171267] usbcore: registered new device driver usb
[ 0.171468] ACPI: WMI: Mapper loaded
[ 0.171472] PCI: Using ACPI for IRQ routing
[ 0.171665] NetLabel: Initializing
[ 0.171669] NetLabel: domain hash size = 128
[ 0.171672] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.171691] NetLabel: unlabeled traffic allowed by default
[ 0.171744] Switching to clocksource tsc
[ 0.172001] AppArmor: AppArmor Filesystem Enabled
[ 0.172001] pnp: PnP ACPI init
[ 0.172001] ACPI: bus type pnp registered
[ 0.174814] pnp: PnP ACPI: found 12 devices
[ 0.174820] ACPI: ACPI bus type pnp unregistered
[ 0.174827] PnPBIOS: Disabled by ACPI PNP
[ 0.174845] system 00:00: iomem range 0xd0000-0xd3fff has been reserved
[ 0.174850] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.174855] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.174859] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.174864] system 00:00: iomem range 0x3fff0000-0x3fffffff could not be reserved
[ 0.174870] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.174874] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.174879] system 00:00: iomem range 0x100000-0x3ffeffff could not be reserved
[ 0.174883] system 00:00: iomem range 0xffee0000-0xffefffff has been reserved
[ 0.174888] system 00:00: iomem range 0xfffe0000-0xfffeffff has been reserved
[ 0.174893] system 00:00: iomem range 0xfec00000-0xfecfffff could not be reserved
[ 0.174897] system 00:00: iomem range 0xfee00000-0xfeefffff has been reserved
[ 0.174908] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.174913] system 00:02: ioport range 0x800-0x805 has been reserved
[ 0.174918] system 00:02: ioport range 0x290-0x297 has been reserved
[ 0.209726] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.209731] pci 0000:00:01.0: IO window: disabled
[ 0.209740] pci 0000:00:01.0: MEM window: 0xe8000000-0xe9ffffff
[ 0.209747] pci 0000:00:01.0: PREFETCH window: 0xd0000000-0xdfffffff
[ 0.209770] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.209774] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.209778] pci_bus 0000:01: resource 1 mem: [0xe8000000-0xe9ffffff]
[ 0.209782] pci_bus 0000:01: resource 2 pref mem [0xd0000000-0xdfffffff]
[ 0.209839] NET: Registered protocol family 2
[ 0.209979] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.210493] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.211395] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.212077] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.212083] TCP reno registered
[ 0.212334] NET: Registered protocol family 1
[ 0.280210] pci 0000:01:00.0: Boot video device
[ 0.280485] Scanning for low memory corruption every 60 seconds
[ 0.280625] audit: initializing netlink socket (disabled)
[ 0.280644] type=2000 audit(1296557162.280:1): initialized
[ 0.288992] Trying to unpack rootfs image as initramfs...
[ 0.300777] highmem bounce pool size: 64 pages
[ 0.300788] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.302850] VFS: Disk quotas dquot_6.5.2
[ 0.302936] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.303797] fuse init (API version 7.13)
[ 0.303928] msgmni has been set to 1716
[ 0.308598] alg: No test for stdrng (krng)
[ 0.308730] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.308736] io scheduler noop registered
[ 0.308739] io scheduler anticipatory registered
[ 0.308742] io scheduler deadline registered
[ 0.308808] io scheduler cfq registered (default)
[ 0.308957] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.308994] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.309103] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.309116] ACPI: Power Button [PWRB]
[ 0.309186] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.309192] ACPI: Sleep Button [FUTS]
[ 0.309280] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.309284] ACPI: Power Button [PWRF]
[ 0.311463] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.311585] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.312073] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.312240] alloc irq_desc for 18 on node -1
[ 0.312245] alloc kstat_irqs on node -1
[ 0.312257] serial 0000:00:02.6: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.312267] serial 0000:00:02.6: PCI INT C disabled
[ 0.313652] brd: module loaded
[ 0.314318] loop: module loaded
[ 0.314474] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.314659] pata_sis 0000:00:02.5: version 0.5.2
[ 0.314684] alloc irq_desc for 16 on node -1
[ 0.314688] alloc kstat_irqs on node -1
[ 0.314697] pata_sis 0000:00:02.5: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.320796] isapnp: Scanning for PnP cards...
[ 0.326323] scsi0 : pata_sis
[ 0.326513] scsi1 : pata_sis
[ 0.327846] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x4000 irq 14
[ 0.327851] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x4008 irq 15
[ 0.328427] Fixed MDIO Bus: probed
[ 0.328488] PPP generic driver version 2.4.2
[ 0.328582] tun: Universal TUN/TAP device driver, 1.6
[ 0.328586] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.328732] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.328768] alloc irq_desc for 23 on node -1
[ 0.328773] alloc kstat_irqs on node -1
[ 0.328785] ehci_hcd 0000:00:03.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 0.328810] ehci_hcd 0000:00:03.3: EHCI Host Controller
[ 0.328869] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 1
[ 0.328917] ehci_hcd 0000:00:03.3: cache line size of 128 is not supported
[ 0.328939] ehci_hcd 0000:00:03.3: irq 23, io mem 0xea021000
[ 0.372706] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00
[ 0.372856] usb usb1: configuration #1 chosen from 1 choice
[ 0.372900] hub 1-0:1.0: USB hub found
[ 0.372918] hub 1-0:1.0: 6 ports detected
[ 0.373004] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.373031] alloc irq_desc for 20 on node -1
[ 0.373035] alloc kstat_irqs on node -1
[ 0.373043] ohci_hcd 0000:00:03.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.373062] ohci_hcd 0000:00:03.0: OHCI Host Controller
[ 0.373117] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 2
[ 0.373145] ohci_hcd 0000:00:03.0: irq 20, io mem 0xea023000
[ 0.466022] usb usb2: configuration #1 chosen from 1 choice
[ 0.466068] hub 2-0:1.0: USB hub found
[ 0.466088] hub 2-0:1.0: 3 ports detected
[ 0.466176] alloc irq_desc for 21 on node -1
[ 0.466181] alloc kstat_irqs on node -1
[ 0.466193] ohci_hcd 0000:00:03.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.466218] ohci_hcd 0000:00:03.1: OHCI Host Controller
[ 0.466289] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 3
[ 0.466327] ohci_hcd 0000:00:03.1: irq 21, io mem 0xea020000
[ 0.500692] ata1.00: ATA-7: Maxtor 6E040L0, NAR61HA0, max UDMA/133
[ 0.500699] ata1.00: 80293248 sectors, multi 16: LBA
[ 0.500749] ata1.01: ATAPI: HL-DT-STDVD-RAM GH22NP20, 1.00, max UDMA/66
[ 0.554376] usb usb3: configuration #1 chosen from 1 choice
[ 0.554427] hub 3-0:1.0: USB hub found
[ 0.554445] hub 3-0:1.0: 3 ports detected
[ 0.554526] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.554670] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.555506] ata1.00: configured for UDMA/133
[ 0.555694] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.555703] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.555924] mice: PS/2 mouse device common for all mice
[ 0.558870] rtc_cmos 00:04: RTC can wake from S4
[ 0.558988] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.559021] rtc0: alarms up to one year, 242 bytes nvram
[ 0.559202] device-mapper: uevent: version 1.0.3
[ 0.559417] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.560735] device-mapper: multipath: version 1.1.0 loaded
[ 0.560742] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.563258] EISA: Probing bus 0 at eisa.0
[ 0.563270] Cannot allocate resource for EISA slot 1
[ 0.563282] Cannot allocate resource for EISA slot 4
[ 0.563301] EISA: Detected 0 cards.
[ 0.563306] cpuidle: using governor ladder
[ 0.563309] cpuidle: using governor menu
[ 0.563904] TCP cubic registered
[ 0.564084] NET: Registered protocol family 10
[ 0.564757] lo: Disabled Privacy Extensions
[ 0.565168] NET: Registered protocol family 17
[ 0.565225] Using IPI No-Shortcut mode
[ 0.565383] registered taskstats version 1
[ 0.565698] rtc_cmos 00:04: setting system clock to 2011-02-01 10:46:02 UTC (1296557162)
[ 0.565704] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.565707] EDD information not available.
[ 0.568728] ata1.01: configured for UDMA/66
[ 0.574545] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.857722] Freeing initrd memory: 7563k freed
[ 0.954042] isapnp: No Plug & Play device found
[ 0.954273] scsi 0:0:0:0: Direct-Access ATA Maxtor 6E040L0 NAR6 PQ: 0 ANSI: 5
[ 0.954542] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.955216] sd 0:0:0:0: [sda] 80293248 512-byte logical blocks: (41.1 GB/38.2 GiB)
[ 0.955300] sd 0:0:0:0: [sda] Write Protect is off
[ 0.955304] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.955345] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.955574] sda:
[ 1.020066] usb 2-3: new low speed USB device using ohci_hcd and address 2
[ 1.200015] usb 2-3: device descriptor read/64, error -62
[ 1.484014] usb 2-3: device descriptor read/64, error -62
[ 1.764015] usb 2-3: new low speed USB device using ohci_hcd and address 3
[ 1.944020] usb 2-3: device descriptor read/64, error -62
[ 2.228014] usb 2-3: device descriptor read/64, error -62
[ 2.508015] usb 2-3: new low speed USB device using ohci_hcd and address 4
[ 2.916012] usb 2-3: device not accepting address 4, error -62
[ 3.055794] sda1 sda2 <
[ 3.056324] scsi 0:0:1:0: CD-ROM HL-DT-ST DVD-RAM GH22NP20 1.00 PQ: 0 ANSI: 5
[ 3.075224] sda5 sda6 >
[ 3.091607] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.091614] Uniform CD-ROM driver Revision: 3.20
[ 3.091743] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 3.091836] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 3.092041] usb 2-3: new low speed USB device using ohci_hcd and address 5
[ 3.092095] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.259262] Freeing unused kernel memory: 620k freed
[ 3.259940] Write protecting the kernel text: 4540k
[ 3.259973] Write protecting the kernel read-only data: 1668k
[ 3.294794] udev: starting version 151
[ 3.500065] usb 2-3: device not accepting address 5, error -62
[ 3.500091] hub 2-0:1.0: unable to enumerate USB device on port 3
[ 3.588420] Floppy drive(s): fd0 is 1.44M
[ 3.608716] FDC 0 is a post-1991 82077
[ 3.648358] sis900.c: v1.08.10 Apr. 2 2006
[ 3.648415] alloc irq_desc for 19 on node -1
[ 3.648420] alloc kstat_irqs on node -1
[ 3.648432] sis900 0000:00:04.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 3.650026] 0000:00:04.0: VIA 6103 PHY transceiver found at address 1.
[ 3.663015] 0000:00:04.0: Using transceiver found at address 1 as default
[ 3.674307] eth0: SiS 900 PCI Fast Ethernet at 0xe400, IRQ 19, 00:11:5b:63:33:82
[ 3.960205] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 15.373257] Adding 1464312k swap on /dev/sda6. Priority:-1 extents:1 across:1464312k
[ 15.436386] udev: starting version 151
[ 15.525703] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x10c0
[ 15.541851] lp: driver loaded but no devices found
[ 15.549864] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 15.658816] Linux agpgart interface v0.103
[ 15.795733] agpgart-sis 0000:00:00.0: SiS chipset [1039/0651]
[ 16.018813] vga16fb: initializing
[ 16.018821] vga16fb: mapped to 0xc00a0000
[ 16.018917] fb0: VGA16 VGA frame buffer device
[ 16.020236] parport_pc 00:09: reported by Plug and Play ACPI
[ 16.020269] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 16.087032] agpgart-sis 0000:00:00.0: AGP aperture is 128M @ 0xe0000000
[ 16.104265] lp0: using parport0 (interrupt-driven).
[ 16.186592] type=1505 audit(1296564378.118:2): operation="profile_load" pid=480 name="/sbin/dhclient3"
[ 16.187279] type=1505 audit(1296564378.118:3): operation="profile_load" pid=480 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 16.187668] type=1505 audit(1296564378.118:4): operation="profile_load" pid=480 name="/usr/lib/connman/scripts/dhclient-script"
[ 16.308117] nvidia: module license 'NVIDIA' taints kernel.
[ 16.308123] Disabling lock debugging due to kernel taint
[ 17.219085] ppdev: user-space parallel port driver
[ 17.506734] psmouse serio1: ID: 10 00 64
[ 17.514045] Intel ICH 0000:00:02.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 17.514159] Console: switching to colour frame buffer device 80x30
[ 17.753882] type=1505 audit(1296564379.686:5): operation="profile_load" pid=636 name="/usr/share/gdm/guest-session/Xsession"
[ 17.767534] type=1505 audit(1296564379.698:6): operation="profile_replace" pid=639 name="/sbin/dhclient3"
[ 17.787253] type=1505 audit(1296564379.718:7): operation="profile_replace" pid=639 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 17.787655] type=1505 audit(1296564379.718:8): operation="profile_replace" pid=639 name="/usr/lib/connman/scripts/dhclient-script"
[ 17.863046] type=1505 audit(1296564379.794:9): operation="profile_load" pid=640 name="/usr/bin/evince"
[ 17.913331] type=1505 audit(1296564379.846:10): operation="profile_load" pid=640 name="/usr/bin/evince-previewer"
[ 17.939356] type=1505 audit(1296564379.870:11): operation="profile_load" pid=640 name="/usr/bin/evince-thumbnailer"
[ 17.960325] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 17.962042] NVRM: loading NVIDIA UNIX x86 Kernel Module 173.14.22 Sun Nov 8 20:26:31 PST 2009
[ 18.088909] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input5
[ 18.348080] intel8x0_measure_ac97_clock: measured 59304 usecs (2853 samples)
[ 18.348087] intel8x0: clocking to 48000
[ 19.252215] agpgart-sis 0000:00:00.0: AGP 3.5 bridge
[ 19.252237] agpgart-sis 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[ 19.252247] agpgart-sis 0000:00:00.0: putting AGP V2 device into 4x mode
[ 19.252307] nvidia 0000:01:00.0: putting AGP V2 device into 4x mode
[ 20.868859] eth0: Media Link On 100mbps full-duplex
[ 22.124076] usb 2-3: new low speed USB device using ohci_hcd and address 6
[ 22.308074] usb 2-3: device descriptor read/64, error -62
[ 22.592163] usb 2-3: device descriptor read/64, error -62
[ 22.863004] usb 2-3: new low speed USB device using ohci_hcd and address 7
[ 23.044073] usb 2-3: device descriptor read/64, error -62
[ 23.328056] usb 2-3: device descriptor read/64, error -62
[ 23.608072] usb 2-3: new low speed USB device using ohci_hcd and address 8
[ 24.016168] usb 2-3: device not accepting address 8, error -62
[ 24.180091] usb 2-3: new low speed USB device using ohci_hcd and address 9
[ 24.588064] usb 2-3: device not accepting address 9, error -62
[ 24.588094] hub 2-0:1.0: unable to enumerate USB device on port 3
[ 28.508033] eth0: no IPv6 routers present
Last edit: 01 Feb 2011 12:58 by andradela.
01 Feb 2011 13:06 #6918 by andypugh
So, that didn't do anything. You already have the firmware.
I was only suggesting that you needed to do that if you could not see any firmware in /lib/firmware/hm2
Can you confirm whether that directory exists, and if there are files in it?
01 Feb 2011 13:16 #6919 by andradela
Yes it exist and has 3 files 7i43 7i43-2 7i43-4.
01 Feb 2011 13:23 #6920 by andypugh
I think those are directories, for the 200k and 400k versions of the 7i43.
Do you know which version you have?
The following user(s) said Thank You: skrap58
01 Feb 2011 13:31 #6923 by andradela
01 Feb 2011 13:34 #6925 by andypugh
andradela wrote:
400k
You need a firmware from the 7i34-4 directory then. Check that the files in the directory match the one in the INI file you are trying to start with.
01 Feb 2011 13:52 #6927 by andradela
has these files.
sv8.bit
sv8.xml
svst4_4.bit
svst4_4.xml
svst4_6.bit
svst4_6.xml
svst4_12.bit
svst4_12.xml
tpen4_5.bit
tpen4_5.xml
01 Feb 2011 13:54 #6928 by andradela
do you have instant messenger?
01 Feb 2011 14:00 #6929 by andypugh
You might be able to get live help on the IRC channel.
www.linuxcnc.org/content/view/4/8/lang,english/
Moderators: PCWjmelson
Time to create page: 0.218 seconds
