Omron Rotary encoders - stepper motors.
31 Aug 2017 02:17 #98252
by jmelson
Jon
Replied by jmelson on topic Omron Rotary encoders - stepper motors.
My Allen-Bradley 7320 had this feature, but it did not have a smooth on/off logic. When the feedrate caused increasing error, the machine jerked to 1/2 the feedrate, the motors caught up, and the cycle repeated. I had to disable it to prevent tipping the mill over.
It _might_ be possible to connect the pid error value to the adaptive feed pin so that step-rate reduces while still making up the lost steps, but I don't know if anyone has ever tried it.
Jon
- Moronicsmurf
- Topic Author
31 Aug 2017 10:10 #98274
by Moronicsmurf
Replied by Moronicsmurf on topic Omron Rotary encoders - stepper motors.
@andypugh i wonder how those "closed loop stepper motors" drivers deal with this then, they are basicly a rotary encoder with a closed loop in its own.. if it would counteract the purpose of it, it would just end up being an interesting experiment i guess..
31 Aug 2017 10:20 #98275
They run like a very high pole-count brushless motor. I think that they also have a torque reserve, the driver is allowed to temporarily over-current as it "knows" what is going on.
Replied by andypugh on topic Omron Rotary encoders - stepper motors.
- Moronicsmurf
- Topic Author
31 Aug 2017 13:24 #98286
by Moronicsmurf
of course that makes sense.. hmm.. Wonder if one could "copy" that behavior within linuxcnc tho.. but some form of "measuring" needs to be performed then.
- Thank you received: 1369
31 Aug 2017 15:03 #98293
Replied by Todd Zuercher on topic Omron Rotary encoders - stepper motors.
Theoretically yes, practically I'm not so sure. Biggest limitation might be timing resolution and granularity (a 1kHz servo thread likely isn't going to be fast enough.)
I've wondered if a high resolution encoder couldn't help with improving the accuracy of a high microsteoped stepper (32x microstepping or so) and limit max following error to something less than 1 full step.
Time to create page: 0.106 seconds
