mesaflash and star tech pci parallel port board not playing nice
10 Sep 2017 16:42 #98783
by JR1050
Im trying to get mesaflash to talk to my 7i90 thru a startech pci1p_lp board. As of now i dont have a computer with an onboard parallel port real handy. The system seems to recognize the board like so
01:06.0 Communication controller: NetMos Technology PCI 1 port parallel adapter (rev 01)
Subsystem: LSI Logic / Symbios Logic Device 0010
Flags: medium devsel, IRQ 19
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at e080
Kernel driver in use: parport_pc
seems like permission is there
zoey@debian:~$ ls -la /dev/parport0
crw-rw---T 1 root lp 99, 0 Sep 9 21:32 /dev/parport0
attempting to locate the 7i90 gets this
zoey@debian:~$ sudo mesaflash --device 7i90 --epp
failed to clear EPP Timeout!
EPP timeout on data cycle of read(addr=0x0000, size=4)
EPP timeout on data cycle of read(addr=0x0100, size=4)
No 7I90 board found
My guess is mesaflash is looking fore the parallel port at 0x0378?
Is this a case of thsi baord just wont do it? I tried to get a board that was known to work in linux for epp.
What am i missing?
system is debian wheezy from the iso
thanks
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at e080
No 7I90 board found
What am i missing?
thanks
10 Sep 2017 16:59 - 10 Sep 2017 17:01 #98784
Replied by PCW on topic mesaflash and star tech pci parallel port board not playing nice
You can set the parallel port address on the mesaflash command line ( with -addr 0xXXXX )
_BUT_ NetMos/MOSChip based PCI parallel cards do not implement EPP correctly so are unlikely to work
Last edit: 10 Sep 2017 17:01 by PCW.
The following user(s) said Thank You: JR1050
10 Sep 2017 23:58 #98807
by JR1050
Replied by JR1050 on topic mesaflash and star tech pci parallel port board not playing nice
The star tech board has the problem you described. I'm stuck in a hurricane anyway, so I dug an old dell out with an onboard p port and put Debian on it. Mesaflash found the 7i90 , we are on our way. Thanks.
Time to create page: 0.073 seconds
