Bit file for Mesa 7i76e with UART?
01 Oct 2017 01:51 #99711 by rodw
Thanks Peter
That seemed to do the trick. I had to compile mesaflash from source from this repository
github.com/micges/mesaflash
And the following was reported
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: created PktUART Interface function hm2_7i76e.0.pktuart.0.
hm2/hm2_7i76e.0:     IO Pin 012 (P1-09): PktUART Transmit Channel #0, pin TX Data (Output)
hm2/hm2_7i76e.0:     IO Pin 013 (P1-10): PktUART Receive Channel #0, pin RX Data (Input)
Full dump from the terminal below
Warning: Spoiler!
Now I just gotta work out what to do from here but Iknow there are a couple of example components that read and write
01 Feb 2018 05:46 #105266 by grijalvap
Can this bit file work with a 5i25 + 7i76,
01 Feb 2018 15:35 #105283 by PCW
No, you need a bifile for a 5I25
24 Mar 2022 04:46 #238189 by nickstewartroc
Thanks Peter
Rod, did you end up getting anywhere with this?
24 Mar 2022 06:44 #238195 by rodw
No, I never ended up with a hypertherm plasma cutter. I have one acquired for a customer on hand now but the serial port is on backorder.
Moderators: PCWjmelson
