leadshine 3nd583 timings
01 Oct 2017 23:05 #99751
by vre
leadshine 3nd583 timings was created by vre
I have a driver leadshine 3nd583 www.leadshine.com/UploadFile/Down/3ND583m.pdf
What step time, step space, direction hold and direction setup must use ?
02 Oct 2017 01:19 #99758
Replied by PCW on topic leadshine 3nd583 timings
Its manual says 1.5 uSec pulse time minimum and 5 uSec direction setup time
direction hold time is not specified
Since direction setup and hold times can be longer that the minimum with little effect on performance
And the pulse width minimum is 1.5 usec I would set the timings like this:
Step time = 2000
Step space = 2000
Dir setup 10000
Dir hold 10000
Step time = 2000
Step space = 2000
Dir setup 10000
Dir hold 10000
The following user(s) said Thank You: vre
21 Aug 2018 10:14 #116395
by mingeki4
Replied by mingeki4 on topic leadshine 3nd583 timings
Step time = 2000
Step space = 2000
Dir setup 10000
Dir hold 10000
I have the some suggestion as the above commentor.
any other question, you can visit our site:
www.oyostepper.com/
Step space = 2000
Dir setup 10000
Dir hold 10000
www.oyostepper.com/
Time to create page: 0.207 seconds
