7i77 terminal numbering question?
12 Oct 2017 23:16 #100297 by Lcvette
so software TB8-0 is not related to TB8 input numbering?
12 Oct 2017 23:19 #100299 by Lcvette
Thank you wouldn't it seem to make sense to have them be the same??? lol
No,what are you going to do with output 0 then?
Board terminal numbers are just that. Has nothing to do inputs outputs. Just a label so you can relate them to whatever is on those pins, so you know where to connect wires.
AH.. I see your meaning
Should be TB8-I0 and TB8-O0
then software and teminal board would Line up!
12 Oct 2017 23:20 #100300 by bevins
There is no TB8-0. I can see how it is a bit confusing in pncconf. That is showing TB8 terminal and input 00 on the first pin. the 00 is the input number not the terminal number. There is no room on that form for terminal numbers. I would imagine thats why that is but....
Now you know, so lets move on to getting it connected.......lol
12 Oct 2017 23:22 #100301 by Lcvette
fair enough! thanks for the insight gentlemen!
much appreciated!
Chris
12 Oct 2017 23:22 #100302 by bevins
TB8 has no 0. It starts at terminal #1 and ends at terminal #32.
It just so happens that inputs 0-15 are on the first 16 terminals and outs 0-7 are on the last 8 terminals.
12 Oct 2017 23:25 #100304 by bevins
You should have a very short stint with pncconf. Get a config going then never go back to pncconf. Editing in an editor for changing and working your config.
Moderators: PCWjmelson
