Communication error with 7i92+7i77
15 Oct 2017 14:28 - 15 Oct 2017 14:33 #100389
by Machinen
Communication error with 7i92+7i77 was created by Machinen
I just bought new 7i92H+7i77 combo. Unfortunately I am having problems with setting it up (so far just on my table).
I flashed the 7i92 with 7i92_7i77x2D.bit using 2m CAT6E patch cable. I am powering both board with ATX power supply 5V by separate lines to both connectors, the field power is 12V from my lab power supply without earth reference. Cable between 7i92H and 7i77 is about 20cm long ribbon cable with idc26->db25 which I did perform continuity test on and also short circuit test. The installation I am using is from linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel , the kernel #1 SMP PREEMPT RT Debian 3.2.93-1, linuxcnc is LINUXCNC - 2.7.11.
When I try theI get theSo it is communicating. However when I tryI do get the following error:Sometimes:Or:Or something like it. IE sometimes the 7i92 communicates with 7i77 more, sometimes less.
I tried both idc26 connectors on the 7i92H.
Any help would be appreciated.
Thanks.
Edit: I forgot to mention that after this the 7i77 usually has the green led rapidly blinking and the red led shut off. To turn it back to no green light and constant red light I have to communicate to it by mesaflash or power cycle the 12V part.
When I try the
mesaflash --device 7i92 --sserial --verbose
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 6
SSLBP Baud Rate: 2500000
interface type: 12
interface width: 8
SSLBP Channel Start: 112
SSLBP Channel Stride: 50
SSLBP Processor Type: d8
SSLBP Clock: 100 MHz
sserial device at channel 3: 7I77 GPIO
SwRevision = 14
NVBaudRate = 2.5Mb
NVUnitNumber = 0x12000xxx
NVWatchDogTimeout = 50ms
EncMode0 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0998]
EncMode1 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099A]
NVEncMode0 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003A]
NVEncMode1 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003C]
SOFTWARE MODE Input_Output [index 00]
SOFTWARE MODE IO_Analog [index 01]
SOFTWARE MODE IO_Analog_FieldVoltage [index 02]
SOFTWARE MODE IO_Encoder_Analog_Fieldvoltage [index 03]
sserial device at channel 4: 7I77 ANALOG
SwRevision = 14
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x11000xxx
SOFTWARE MODE AnalogOut_Enables [index 00]
halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="192.168.1.121"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: MAC
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: hm2_sserial_waitfor: Timeout (51mS) waiting for addr 5b00 &mask ffffffff val 800
hm2/hm2_7i92.0: DATA addr 5c00 after timeout: 800
hm2/hm2_7i92.0: failed to parse Module Descriptor 5
board fails HM2 registration
hm2_eth: rtapi_app_main: Invalid argument (-22)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_eth
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_eth failed, returned -1
Board hm2_7i92.0.7i77.0.3 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.3 Software Mode 0 = input_output
hm2/hm2_7i92.0: hm2_sserial_waitfor: Timeout (24mS) waiting for addr 5d0c &mask ff00 val 0
hm2/hm2_7i92.0: DATA addr 5e0c after timeout: 400000
hm2/hm2_7i92.0: Timeout trying to read config data in sserial_get_bytes
<stdin>:4: waitpid failed /usr/bin/rtapi_app hm2_eth
<stdin>:4: /usr/bin/rtapi_app exited without becoming ready
<stdin>:4: insmod for hm2_eth failed, returned -1
Board hm2_7i92.0.7i77.0.3 Software Mode 1 = io_analog
hm2/hm2_7i92.0: hm2_sserial_waitfor: Timeout (25mS) waiting for addr 5b00 &mask ffffffff val 0
hm2/hm2_7i92.0: DATA addr 5c00 after timeout: 0
hm2/hm2_7i92.0: Timeout during do-it in sserial_get_bytes
hm2/hm2_7i92.0: hm2_sserial_waitfor: Timeout (25mS) waiting for addr 5b00 &mask ffffffff val 1008
hm2/hm2_7i92.0: DATA addr 5c00 after timeout: 1008
Board hm2_7i92.0.7i77.0.3 Software Mode 2 = io_analog
<stdin>:9: waitpid failed /usr/bin/rtapi_app hm2_eth
<stdin>:9: /usr/bin/rtapi_app exited without becoming ready
<stdin>:9: insmod for hm2_eth failed, returned -1
Thanks.
Last edit: 15 Oct 2017 14:33 by Machinen.
15 Oct 2017 14:35 - 15 Oct 2017 15:19 #100390
Replied by PCW on topic Communication error with 7i92+7i77
Did you run a latency test on the host PC?
What is you host hardware?
The rapid green LED blinking likely means that the host has lost all communication with the 7I92 some time
during the sserial setup phase and its been left in the channel started phase but no commands have been issued
Last edit: 15 Oct 2017 15:19 by PCW.
15 Oct 2017 15:27 #100393
by Machinen
Replied by Machinen on topic Communication error with 7i92+7i77
I actually did, the max jitter was on base thread under 50000ns and about half on servo thread.
The hardware is
I assumed something like it with the blinking green led.
The hardware is
sudo lshw -short
H/W path Device Class Description
system To Be Filled By O.E.M.
/0 bus P4P800
/0/0 memory 64KiB BIOS
/0/4 processor Intel(R) Pentium(R) 4 CPU 2.40GHz
/0/4/5 memory 8KiB L1 cache
/0/4/6 memory 512KiB L2 cache
/0/4/0.1 processor Logical CPU
/0/4/0.2 processor Logical CPU
/0/38 memory 2GiB System Memory
/0/38/0 memory 512MiB DIMM SDRAM Synchronous
/0/38/1 memory 512MiB DIMM SDRAM Synchronous
/0/38/2 memory 512MiB DIMM SDRAM Synchronous
/0/38/3 memory 512MiB DIMM SDRAM Synchronous
/0/100 bridge 82865G/PE/P DRAM Controller/Host-H
/0/100/1 bridge 82865G/PE/P AGP Bridge
/0/100/1/0 display Radeon R200 QM [Radeon 9100]
/0/100/6 generic 82865G/PE/P Processor to I/O Memor
/0/100/1d bus 82801EB/ER (ICH5/ICH5R) USB UHCI C
/0/100/1d.1 bus 82801EB/ER (ICH5/ICH5R) USB UHCI C
/0/100/1d.2 bus 82801EB/ER (ICH5/ICH5R) USB UHCI C
/0/100/1d.3 bus 82801EB/ER (ICH5/ICH5R) USB UHCI C
/0/100/1d.7 bus 82801EB/ER (ICH5/ICH5R) USB2 EHCI
/0/100/1e bridge 82801 PCI Bridge
/0/100/1e/b eth0 network RTL-8139/8139C/8139C+
/0/100/1e/5 eth1 network 3c940 10/100/1000Base-T [Marvell]
/0/100/1f bridge 82801EB/ER (ICH5/ICH5R) LPC Interf
/0/100/1f.1 scsi0 storage 82801EB/ER (ICH5/ICH5R) IDE Contro
/0/100/1f.1/0.0.0 /dev/sda disk 40GB ST340014A
/0/100/1f.1/0.0.0/1 /dev/sda1 volume 35GiB EXT4 volume
/0/100/1f.1/0.0.0/2 /dev/sda2 volume 1594MiB Extended partition
/0/100/1f.1/0.0.0/2/5 /dev/sda5 volume 1594MiB Linux swap / Solaris parti
/0/100/1f.1/0.1.0 /dev/sdb disk 40GB ST340016A
/0/100/1f.1/0.1.0/1 /dev/sdb1 volume 35GiB EXT4 volume
/0/100/1f.1/0.1.0/2 /dev/sdb2 volume 1594MiB Extended partition
/0/100/1f.1/0.1.0/2/5 /dev/sdb5 volume 1594MiB Linux swap / Solaris parti
/0/100/1f.3 bus 82801EB/ER (ICH5/ICH5R) SMBus Cont
/0/100/1f.5 multimedia 82801EB/ER (ICH5/ICH5R) AC'97 Audi
15 Oct 2017 16:18 - 15 Oct 2017 16:18 #100395
Which Ethernet is the 7I92 connected to?
Do you have the 192.168.1.121 range overlapping with the other Ethernet?
Normally its suggested to use 10.10.10.10 for the 7I92 and 10.10.10.1 for the host
because this does not overlap common NAT ranges
Last edit: 15 Oct 2017 16:18 by PCW.
15 Oct 2017 16:39 #100399
by Machinen
It's the eth1 3c940 10/100/1000Base-T [Marvell] - the motherboard network card. The extra eth0 is for home network. For local network, I am using 192.168.88.0/24 so there should not be any overlap.
Last evening I even tried the 10.10.10.10 settings but with no effect - or actually there was one effect, for some reason the mesaflash --device 7i92 --sserial took forever on the 7i77 part.
I can try it again.
I can try it again.
15 Oct 2017 16:46 #100400
I would try the RT8139 for the 7I92
Marvel and Broadcom are known not working for real time
On mesaflash you need to supply the address if you use 10.10.10.10
(and the host needs to be configured properly as well)
15 Oct 2017 16:51 #100401
by Machinen
OK, did change+restart and tried:And blinking cursor at the end.
Then after minute or soAnd blinking cursor again.
mesaflash --device 7i92 --addr 10.10.10.10 --sserial --verbose
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 6
interface type: 12
interface width: 8
15 Oct 2017 17:05 #100402
Weird, Host network setup error?
what does
/sbin/ifconfig
show?
what does
/sbin/ifconfig
show?
15 Oct 2017 17:43 - 15 Oct 2017 17:47 #100406
by Machinen
Had to change local language
Ok, the output:
EDIT: OK, did quick change of eth interfaces, reloaded networking and I will be damned, it works! Frankly, I probably wouldn't try it for some time, so thanks a lot.
Ok, the output:
/sbin/ifconfig
eth0 Link encap:Ethernet HWaddr 00:08:54:05:53:76
inet addr:192.168.88.86 Bcast:192.168.88.255 Mask:255.255.255.0
inet6 addr: fe80::208:54ff:fe05:5376/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:316 errors:0 dropped:0 overruns:0 frame:0
TX packets:199 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:75731 (73.9 KiB) TX bytes:24839 (24.2 KiB)
Interrupt:22 Base address:0xe400
eth1 Link encap:Ethernet HWaddr 00:0c:6e:41:73:79
inet addr:10.10.10.1 Bcast:10.255.255.255 Mask:255.0.0.0
inet6 addr: fe80::20c:6eff:fe41:7379/64 Scope:Link
RX packets:980 errors:0 dropped:0 overruns:0 frame:0
TX packets:1551 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:62770 (61.2 KiB) TX bytes:104674 (102.2 KiB)
Interrupt:22
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:720 (720.0 B) TX bytes:720 (720.0 B)
Last edit: 15 Oct 2017 17:47 by Machinen.
- Thank you received: 5909
20 Oct 2017 09:11 #100578
Replied by tommylight on topic Communication error with 7i92+7i77
For reliable eth connection when using 2 or more eth interfaces on the same computer, this has to be done for the port that the 7i92 or 7i76E is connected to :
Network manager chose "edit connections", double click on the wired connection , go to "ipv4" tab, change from automatic DHCP to manual, under it add the propper address ( 10.10.10.x or 192.168.1.x depending on the address set on the mesa board ), on that same page there is another button on the bottom right side ( am on the phone so i do not recall the label but most probably Advanced ), click on " use this connection for local....something. ok. Ok. Ok That is it.
