Break-out-board compatibility
19 Oct 2017 15:15 #100558
by Aziris
Break-out-board compatibility was created by Aziris
Hi guys,
If I am running Mach3 over Parallel Port to my Chineese BOB with success, is there any chance LinuxCNC would require a different BOB?
BR,
Maris
BR,
Maris
19 Oct 2017 16:00 #100559
Replied by PCW on topic Break-out-board compatibility
Almost any Mach compatible parallel port BOB should work with LinuxCNC
Also LinuxCNCs parallel port configuration tool ( stepconf ) can read Mach xml files to
minimize the work needed to change to LinuxCNC
The following user(s) said Thank You: Tchefter
Time to create page: 0.069 seconds
