Connecting Smart-Serial cables.
15 Aug 2021 15:30 #217819
Connecting Smart-Serial cables. was created by andypugh
For no good reason I have never been totally happy cutting down a CAT5 cable and clamping the ends in a terminal block. So I came up with an alternative.
This is an 8P8C connector and a little PCB that I had made. Actually I had a lot pc PCBs made. 50.
The PCB was made small enough to fit between the rows of the 7i69, as shown above. But for a 7i76 there is not room, However a different terminal block can be used:
And that actually works with the first design of PCB that I had made, before realising that I had made them too large for the gap.
So, I now have something like 100 PCBs (and 20 sockets) of which I will only ever use a small fraction. Does anyone want one?
The following user(s) said Thank You: BigJohnT, Roguish, jtc, Clive S, tivoi, besriworld, Aciera, Markyd
15 Aug 2021 16:37 #217831
by scotth
Replied by scotth on topic Connecting Smart-Serial cables.
I find this far more elegant. How do I get on the list and how do we reimburse your cost?
15 Aug 2021 16:41 #217832
by Clive S
+1 Andy as above
Replied by Clive S on topic Connecting Smart-Serial cables.
+1 Andy as above
15 Aug 2021 19:42 #217841
by Roiki
Replied by Roiki on topic Connecting Smart-Serial cables.
FYI you can find similar stuff on eBay by searching "rj45 breakout".
I've used stuff like these with great success.
15 Aug 2021 20:03 #217843
Replied by andypugh on topic Connecting Smart-Serial cables.
Those don't really solve the problem of going from Mesa-card Phoenix connectors to CAT5 cable.I've used stuff like these with great success.
- Thank you received: 5948
16 Aug 2021 00:15 #217850
Replied by tommylight on topic Connecting Smart-Serial cables.
I could use 2 or 3 of them, but it will be to much trouble for you, so i am kicking myself out of the list !
16 Aug 2021 11:26 - 16 Aug 2021 11:29 #217875
by Roiki
Solved it for me.Those don't really solve the problem of going from Mesa-card Phoenix connectors to CAT5 cable.
Last edit: 16 Aug 2021 11:29 by Roiki.
20 Aug 2021 19:27 #218268
by BigJohnT
Replied by BigJohnT on topic Connecting Smart-Serial cables.
I'd be interested in offering them in my Mesa store if you think you can send them as a sample of no value or as a gift. I assume the Cat5 plugs are standard and I can get them over here. I can PayPal you for the boards and postage.
JT
JT
01 Dec 2021 22:27 #228158
by BigJohnT
Andy,
Thanks for sending me some Smart Serial Card Connectors, what is the part number for the RJ-45 Connector? I'll try and get some on this side of the pond and finish the 20 bare boards.
JT
JT
09 Dec 2021 21:38 #228739
lcsc.com/product-detail/Ethernet-Connect...8P-B000_C386763.html
Is what I used.
Others may have the same hole pattern and pinout.
Is what I used.
Time to create page: 0.553 seconds
