Mesaflash Firmware
10 Nov 2021 22:15 #226040
by paulsao
Mesaflash Firmware was created by paulsao
Greetings everyone, I want to use the ohmic component to change my plasma table from float switch to one of ohmic sense, so I investigated I need to write the firmware 7i96pl.bit to enable the encoder input that I need to connect my THCAD, which I need Is it help with how to burn my firmware with (Mesaflash) and know if that changes the current configuration of my table?
11 Nov 2021 05:09 #226062
Replied by rodw on topic Mesaflash Firmware
To get mesaflash, you can follow the instructions here
github.com/LinuxCNC/mesaflash
I think it may also be included in the linuxcnc-dev package.
mesaflash --help will give you the syntax
It will not affect your current config at all. It jut puts extra encoder A's on the Encoder B and Index pins. These will show up under encoder in halshow (power cycle the Mesa card first)
You'll need my component. When you get there, ask and I'll dig it out for sharing (but I need to be at work)
The following user(s) said Thank You: paulsao
11 Nov 2021 14:04 - 11 Nov 2021 14:08 #226110
by paulsao
Replied by paulsao on topic Mesaflash Firmware
Thanks Rodw for your great help, now I want to assemble the electrical circuit and I saw this diagram that I attached, I have another thcad-10 that I am going to use, my question is the following: I do not have a torch with an isolation (shield) I can connect directly to the torch without isolating, I have a low frequency plasma, I think the THCAD is designed for that and the only problem could be the power source but the relay already protects it, if you can give me some advice I would appreciate it.
Last edit: 11 Nov 2021 14:08 by paulsao.
11 Nov 2021 17:29 #226120
by BigJohnT
Replied by BigJohnT on topic Mesaflash Firmware
11 Nov 2021 18:49 #226128
by paulsao
Thanks for you help, I need flash 7i96dpl.bit but this firmware doest in the list.
11 Nov 2021 18:51 #226129
I'm not aware of anybody using on an unshielded torch like yours.
Provided you use an isolated power supply like the (Meanwell HDR-15-24), it should work.
That means you will have overvoltage protection to 500 volts in the circuit.
In testing, even with a shielded torch, we do see the torch voltage in the circuit when cutting, So I'm sure its OK.
You will need to calculate the correct resistor to give 24.5 volt approx with the THCAD-10
11 Nov 2021 20:14 #226138
by paulsao
7i96 g540dpl is the same firmaware that 7i96dpl?
11 Nov 2021 22:23 - 11 Nov 2021 22:27 #226152
by paulsao
You can also use my configuration tool to flash the 7i96.
gnipsel.com/mesa/7i96/index.html
JT
Thanks JT for your help, what is the firmware to enable the other encoder entry that I need from the list of your program I can't find the 7i96dpl.bit
Last edit: 11 Nov 2021 22:27 by paulsao.
12 Nov 2021 16:01 #226226
by paulsao
Rod, could you help me with the component ohmic3 and the information to install and test it?
Paul.
Paul.
12 Nov 2021 23:54 #226255
by BigJohnT
JT
I see that was recently added so I need to update my configuration tool. I'll do that in the morning...
JT
JT
Time to create page: 0.256 seconds
