7I76e will ping but wont connect with Linuxcnc
- Jalapeno56
- Thank you received: 17
18 Jan 2022 22:07 #232339
by Jalapeno56
7I76e will ping but wont connect with Linuxcnc was created by Jalapeno56
I am running Debian Bullseye with kernel 5.10.0-10-rt-amd64, linuxcnc 2.9
I can ping my 7I76e and see it on ip a:
bryan@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether c0:25:a5:91:90:85 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global enp1s0
3: wlx1cbfce7a8336: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 1c:bf:ce:7a:83:36 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.36/24 brd 192.168.1.255 scope global dynamic noprefixroute wlx1cbfce7a8336
valid_lft 78331sec preferred_lft 78331sec
inet6 fe80::3f28:fbcd:2ff1:63e4/64 scope link noprefixroute
However, every time i start linuxcnc i get this error:
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.11: Resource temporarily unavailable
I have been through multiple forums and tried everything I can find, any help is much appreciated!!
- Thank you received: 5329
18 Jan 2022 22:25 - 18 Jan 2022 22:26 #232342
Replied by PCW on topic 7I76e will ping but wont connect with Linuxcnc
Normally the 7I76E would have a IP address of 10.10.10.10,
did you change this?
If not, you should edit your hal/ini file and change the IP address to 10.10.10.10
Last edit: 18 Jan 2022 22:26 by PCW. Reason: sp
- Jalapeno56
18 Jan 2022 22:30 #232343
by Jalapeno56
Replied by Jalapeno56 on topic 7I76e will ping but wont connect with Linuxcnc
That is what i initially started with. Other forums suggested to stay away from .1-.10 and use .11-.255, none of which have worked.
18 Jan 2022 22:40 #232344
I'm not asking about the host address, but rather the 7I76E's IP address.
Unless you specifically changed this address, you need to edit your hal/ini file
and change 10.10.10.11 to 10.10.10.10
The following user(s) said Thank You: Jalapeno56
- Jalapeno56
18 Jan 2022 22:46 #232345
by Jalapeno56
Yes sir, Just did, edited the .hal file again to .10, restart linuxcnc, same error. I even made sure the static ip in network manager under ipv4 matched.
18 Jan 2022 22:48 #232346
If the host address matches it will not work.
Use 10.10.10.100 for the host address
(and 10.10.10.10 for the 7I76E address in the hal/in file)
- Jalapeno56
18 Jan 2022 22:53 #232347
by Jalapeno56
Changed host to .100, .hal still at .10, same result
18 Jan 2022 22:55 #232348
OK without changing anything can you run:
ip a
and
ping 10.10.10.10
and post the results here
ip a
and
ping 10.10.10.10
- Jalapeno56
18 Jan 2022 22:59 #232351
by Jalapeno56
inet 10.10.10.11/8 brd 10.255.255.255 scope global noprefixroute enp1s0
valid_lft 74032sec preferred_lft 74032sec
bryan@debian:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
From 10.10.10.11 icmp_seq=1 Destination Host Unreachable
From 10.10.10.11 icmp_seq=2 Destination Host Unreachable
From 10.10.10.11 icmp_seq=3 Destination Host Unreachable
From 10.10.10.11 icmp_seq=4 Destination Host Unreachable
From 10.10.10.11 icmp_seq=5 Destination Host Unreachable
From 10.10.10.11 icmp_seq=6 Destination Host Unreachable
I must still have .11 stuck somewhere....
18 Jan 2022 23:06 #232355
10.10.10.11 is the host address:
"inet 10.10.10.11/8 brd 10.255.255.255 scope global noprefixroute enp1s0"
Do you have the 7I76E set for 10.10.10.10?
(W2 Down W3 UP and a power cycle)
Time to create page: 0.234 seconds
