Mesa 7i92 Dolt not cleared
19 Jun 2022 14:10 #245431
by DoWerna
I also keep getting this error.
The computer is an HP8300, the fanduct is installed.
The latency test during installation was inconspicuous.
forum.linuxcnc.org/media/kunena/attachme...01-18at22.57.15.jpeg
Mesa 7i92 Dolt not cleared was created by DoWerna
- Thank you received: 5946
19 Jun 2022 15:30 #245435
Replied by tommylight on topic Mesa 7i92 Dolt not cleared
Moved to "driver boards" and renamed to reflect the issue, this is not the same as "unexpected realtime delay" errors.
Things to check:
-5V power supply
-servo period should be 1000000 (1 Million) in the ini file
-Network cable
-any of the 7i92 pins wired to a high load
-interference from VFD
Things to check:
-5V power supply
-Network cable
19 Jun 2022 21:29 #245452
Replied by PCW on topic Mesa 7i92 Dolt not cleared
Check all tmax values to see where the error lies:
( when LinuxCNC is running )
halcmd show param *.tmax
To interpret these values, the CPU frequency and the servo thread
period are also needed.
The following user(s) said Thank You: DoWerna
20 Jun 2022 06:19 #245471
by DoWerna
Replied by DoWerna on topic Mesa 7i92 Dolt not cleared
thanks
I will check the tmax values as soon as I am at the machine.
can it be due to an unsuitable cable between 7i77 and 7i73?
there was already a thin-wire shielded 24-pole cable in the machine.
with this I connected the 7i73 to the 7i77.
Only 8 wires of this cable were used for the serial connection, the other wires are unused,
But it runs parallel with the cables to the servo motors of X and Z.
The 7i73 still drives some control lamps, but with an uln2003 chip.
Maybe the 5V supply of 7i73 is too weak?
20 Jun 2022 07:33 #245473
by DoWerna
servo thread 1000000
Parameters:
Owner Type Dir Value Name
47 s32 RW 1803 and2_manualmode.tmax
47 s32 RW 5673 and_manual_1.tmax
47 s32 RW 1917 and_pause_1.tmax
47 s32 RW 2100 and_pause_2.tmax
47 s32 RW 8295 and_run.tmax
47 s32 RW 8298 and_step.tmax
56 s32 RW 10227 conv_feed.tmax
35 s32 RW 9222 debounce.0.tmax
35 s32 RW 2406 debounce.1.tmax
77 s32 RW 6762 edge_manualmode.tmax
50 s32 RW 8946 gear.tmax
26 s32 RW 0 hm2_7i92.0.read-request.tmax
26 s32 RW 1205697 hm2_7i92.0.read.tmax
26 s32 RW 538452 hm2_7i92.0.write.tmax
32 s32 RW 10086 matrix_panel.tmax
19 s32 RW 7830 motion-command-handler.tmax
19 s32 RW 56016 motion-controller.tmax
74 s32 RW 7086 mux2_handrad0001.tmax
74 s32 RW 2673 mux2_handrad001.tmax
74 s32 RW 8715 mux2_handrad01.tmax
74 s32 RW 6789 mux2_manualmode_x.tmax
74 s32 RW 8301 mux2_manualmode_z.tmax
53 s32 RW 7008 muxfeed.tmax
62 s32 RW 6912 near.0.tmax
80 s32 RW 8823 not_manualmode.tmax
44 s32 RW 6993 or_feed.tmax
44 s32 RW 1581 or_pause.tmax
44 s32 RW 6774 or_tool-confirm.tmax
29 s32 RW 11973 pid.s.do-pid-calcs.tmax
29 s32 RW 9585 pid.x.do-pid-calcs.tmax
29 s32 RW 8346 pid.z.do-pid-calcs.tmax
20 s32 RW 1455840 servo-thread.tmax
47 s32 RW 6507 shw.and7.tmax
47 s32 RW 1566 shw.and8.tmax
47 s32 RW 7521 shw.and9.tmax
68 s32 RW 9246 shw.enc-smooth.tmax
71 s32 RW 6804 shw.ff-0001.tmax
71 s32 RW 2061 shw.ff-001.tmax
71 s32 RW 8256 shw.ff-01.tmax
71 s32 RW 10863 shw.ff-step-lock.tmax
71 s32 RW 7473 shw.ff-x.tmax
71 s32 RW 1866 shw.ff-xyz-lock.tmax
71 s32 RW 6732 shw.ff-z.tmax
65 s32 RW 2214 shw.lock-step.tmax
65 s32 RW 6258 shw.lock-xyz.tmax
65 s32 RW 7572 shw.nor-step.tmax
65 s32 RW 6369 shw.nor-xyz.tmax
104 s32 RW 9468 shw.set-ff.tmax
53 s32 RW 7086 shw.step-choice.tmax
59 s32 RW 7218 spindle_abs.tmax
41 s32 RW 8229 toggle2n_flood.tmax
41 s32 RW 9111 toggle2n_pause.tmax
38 s32 RW 8436 toggle_flood.tmax
38 s32 RW 8769 toggle_manual.tmax
38 s32 RW 7356 toggle_pause.tmax
38 s32 RW 7866 toggle_turtle.tmaxhalcmd show param *.tmax
Parameters:
20 Jun 2022 13:51 #245483
What is the CPU speed?
21 Jun 2022 14:05 #245535
by DoWerna
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 36 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 42
Model name: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Stepping: 7
CPU MHz: 1596.286
CPU max MHz: 3700.0000
CPU min MHz: 1600.0000
BogoMIPS: 6584.73
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 6144K
NUMA node0 CPU(s): 0-3
CPU(s): 4
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 42
Stepping: 7
CPU MHz: 1596.286
BogoMIPS: 6584.73
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 6144K
21 Jun 2022 14:12 - 21 Jun 2022 14:13 #245536
OK so the timings look OK
Does your system have a Intel Ethernet chip?
What are your ping times if you ping the 7I92?
Last edit: 21 Jun 2022 14:13 by PCW.
22 Jun 2022 06:45 #245580
by DoWerna
ping timings
ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=1 ttl=64 time=0.392 ms
64 bytes from 192.168.1.121: icmp_seq=2 ttl=64 time=0.240 ms
64 bytes from 192.168.1.121: icmp_seq=3 ttl=64 time=0.165 ms
64 bytes from 192.168.1.121: icmp_seq=4 ttl=64 time=0.221 ms
64 bytes from 192.168.1.121: icmp_seq=5 ttl=64 time=0.139 ms
64 bytes from 192.168.1.121: icmp_seq=6 ttl=64 time=0.226 ms
64 bytes from 192.168.1.121: icmp_seq=7 ttl=64 time=0.166 ms
64 bytes from 192.168.1.121: icmp_seq=8 ttl=64 time=0.120 ms
64 bytes from 192.168.1.121: icmp_seq=9 ttl=64 time=0.175 ms
64 bytes from 192.168.1.121: icmp_seq=10 ttl=64 time=0.281 ms
64 bytes from 192.168.1.121: icmp_seq=11 ttl=64 time=0.360 ms
64 bytes from 192.168.1.121: icmp_seq=12 ttl=64 time=0.116 ms
64 bytes from 192.168.1.121: icmp_seq=13 ttl=64 time=0.321 ms
64 bytes from 192.168.1.121: icmp_seq=14 ttl=64 time=0.385 ms
64 bytes from 192.168.1.121: icmp_seq=15 ttl=64 time=0.280 ms
64 bytes from 192.168.1.121: icmp_seq=16 ttl=64 time=0.289 ms
64 bytes from 192.168.1.121: icmp_seq=17 ttl=64 time=0.324 ms
64 bytes from 192.168.1.121: icmp_seq=18 ttl=64 time=0.336 ms
Is there a terminal command with which I can display my network chip?
ping 192.168.1.121
22 Jun 2022 12:55 #245593
Those ping times look pretty bad...
You might try:
dmesg | grep -i eth
You might try:
dmesg | grep -i eth
Time to create page: 0.216 seconds
