Mesa Configuration Tool
31 Aug 2022 11:28 #250852 by ajja
Mesa Configuration Tool was created by ajja
thanks a lot for all the very helpful work,
Since I don't have a git account I am filing here a little bug report for the mesact configuration tool ( great stuff by the way !):
When trying to reopen the tool I got the following error:
File os.py line 225, in makedirs
["FileExistsError: [Errno 17] File exists: '/home/mitad/.config/measct'\n"]
It seems that /measct cannot be overwritten on reopening, if I delete the folder manually mesact opens normally.
Sorry if this report is not at the right place, feel free to move/delete it.
ajja
31 Aug 2022 22:05 #250898 by JT
Replied by JT on topic Mesa Configuration Tool
Are you using the latest version of the Mesa Configuration Tool?
JT
31 Aug 2022 23:05 #250902 by ajja
Replied by ajja on topic Mesa Configuration Tool
yes latest version from master/ mesact_0.7.0_amd64.deb
Apparently it is because I didn't finish up to validation before closing the program the first time. Now that I have completed a configuration I don't get the error anymore
01 Sep 2022 12:56 #250920 by JT
The latest is 0.7.1 Build Date 8/24/2022
JT
The following user(s) said Thank You: tommylight, Clive S, tivoi
05 Sep 2022 00:30 #251196 by joshwuh
Replied by joshwuh on topic Mesa Configuration Tool
FYI - not sure if it is intended to be a functioning tool yet but the latest tool appears to have a bug that prevents building the config file:
I set the bare minimum configuration to build the tool, and the last error is as follows:
Axes Tab
Multiple Joint Axis must be negative for at least one Joint.
That's with an XYZ configuration (no tandem axis). If I change it to an XYYZ configuration (joint 0,1,2,3 respectively) then it will change the error to something like:
Axes Tab
Multiple Joint Axis Y joint1 & joint2 must be negative for at least one Joint.
If you set scale to -1 OR reverse direction (but not both) you continue getting this error. If you set scale to -1 AND reverse direction you get a new, additional error stating that you must pick one or the other.
12 Sep 2022 13:55 #251737 by JT
Yes it is my intention that the tool works and works above and beyond what other tools do.
Sorry about the bug, it has been fixed a couple of days ago.
JT
16 Sep 2022 16:38 #252087 by HansU
Replied by HansU on topic Mesa Configuration Tool
I wanted to create a configuration for a 5i25 + 7i85s.
It seems that the 7i85s is not fully supported yet.
I get this when trying to select the 7i85s:
And in the Axes tab it still says 7i77
Furthermore I wonder about the meaning of the bit/pin files in the 5i25/holding folder. Are those the not yet supported ones?
16 Sep 2022 18:21 #252095 by JT
Thanks for the feedback, I'll correct that in the morning.
Yes, as I add support for bit files I move them from holding.
JT
16 Sep 2022 20:36 #252116 by JT
I fixed the errors and you "should" be able to configure your axes but didn't have time to test that. Download a fresh copy of the deb from the menu File > Download Amd64 Deb in mesact.
JT
The following user(s) said Thank You: HansU
17 Sep 2022 16:36 - 17 Sep 2022 16:37 #252177 by HansU
A comment on the commit "fix checking for linuxcnc version I hope"
If I set the localization to en, then it works for me. But with German locale if didn't work because your query gives this:
$ apt-cache policy linuxcnc-uspace
linuxcnc-uspace:
    Installiert: 1:2.8.3
Not sure how to get this fixed multilangual.
Last edit: 17 Sep 2022 16:37 by HansU.
Moderators: PCWjmelson
Time to create page: 0.138 seconds
