Mesa cards for BP412 Servo's
- GDTH
- Topic Author
2 years 10 months ago #287965
by GDTH
Mesa cards for BP412 Servo's was created by GDTH
Hello Everyone,I'm excited to share that I'm embarking on a new adventure (BP412) in the upcoming months. To give you some context, I've previously worked with a CNC ISEL and an Emco 120, both paired with a 7C80 controller. These setups have worked well for me, but I've noticed that Linux runs quite slowly on a Raspberry Pi compared to a second-hand PC.Recently, I've been focused on working with a Bridgeport Interact 4 Series 2, using a 7I80DB-25 controller alongside a 7i76 and three servos. This setup has been running smoothly with a second-hand PC equipped with a dedicated Ethernet card.Now, with the new machine, I'm inclined to go analog as I believe it will offer better performance. My initial plan was to use a 7I80DB-25 paired with a 7i77, but I've encountered a challenge – the 7i77 is currently unavailable through eusurplus.I have a few questions and would appreciate any advice you can offer:
Considering the unavailability of the 7i77, would the Mesa 7I97 Ethernet-interfaced Analog servo plus I/O is a viable alternative, despite having only 16 outputs and 16 inputs.
- Is there a chance that the 7i77 might become available again in the future?
- What are the key differences between the Mesa 7i80HDT, HD-16, and HD25, and how do they compare when paired with a 7i33TA or 7I48? Are there significant variations in performance, especially concerning the number of supported axes?
- As a last option, the 7i83. However, I'm curious if there are any noticeable performance differences between this card and the 7i33TA, 7i48, and the currently unavailable 7i77.
- Thank you received: 5334
2 years 10 months ago #287968
Replied by PCW on topic Mesa cards for BP412 Servo's
If you can find a 7I97 it should work as well as a FPGA card+ 7I77 if its has
sufficient digital I/O.
We are building 7I77s and they should be available in about 8 weeks.
Normally you would choose an FPGA card that matches the daughtercard
(so 50 pin FPGA cards for 50 pin daughtercards and 25 pin FPGA cards for 25 pin daughtercards)
A 7I83 is basically identical to the analog section of a 7I77 (with the advantage of isolation from the controller)
If you need an immediate solution, a 7I95T+7I83 will work for analog servo control
- B.Reilly01
- Thank you received: 24
2 years 10 months ago - 2 years 10 months ago #287979
by B.Reilly01
Replied by B.Reilly01 on topic Mesa cards for BP412 Servo's
I'm doing a brisgeport interact 412 right now! One thing of note is that the encoders are not usable... they are an old analog style, and they are built into the servo motors. I believe I'm past that problem, modifying the encoder caps and mounting new encoders. I'm using a7i97t and 7i76 for more io.
Last edit: 2 years 10 months ago by B.Reilly01.
Time to create page: 0.272 seconds
