address of the parallel port with lspci -v
29 Dec 2010 14:23 - 02 Jan 2011 11:54 #6310 by sebastian1933
Determine the hardware address of the parallel port with no lspci-v meaningful
query the HW address with lspci does not show me 0x378 for the port 0 and not for the other ports.
In the computer 2 additional interface cards, each with 2 ports are installed, that are 5 physical printer ports available.
I saved two files: one lspci-v and even lspci-v | grep I / O and attached here.
How do I get the address in the form 0x378, 0x278 ... out.
What are the pin names or addresses of the interfaces with 2 per card?
Thanks for the help,
Your Sebastian
File Name: lspci.zip
File Size:2 KB
Last edit: 02 Jan 2011 11:54 by sebastian1933.
06 Feb 2011 22:58 #7033 by andypugh
Sorry for the late reply.
01:06.0 Communication controller: NetMos Technology PCI 9815 Multi-I/O Controller (rev 01)
Subsystem: LSI Logic / Symbios Logic 2P0S (2 port parallel adaptor)
Flags: medium devsel, IRQ 5
I/O ports at cf00
I/O ports at ce00
I/O ports at cd00
I/O ports at cc00
I/O ports at cb00
I/O ports at ca00
01:07.0 Communication controller: NetMos Technology PCI 9815 Multi-I/O Controller (rev 01)
Flags: medium devsel, IRQ 10
I/O ports at c900
I/O ports at c800
I/O ports at c700
I/O ports at c600
I/O ports at c500
I/O ports at c400
All I can suggest is trying all of the above. (0xC400, 0xC500…..) and seeing if any work.
I might even be tempted to try the thing which reports as an IDE interface, it might be the onboard port. The next puzzle would then be to find which other address is the epp high register, as none of them seem to have the expected 0x400 gap.
07 Feb 2011 12:03 #7048 by BigJohnT
07 Feb 2011 12:19 #7049 by andypugh
Probably worth a try. I have never tried it. (I am not sure if the original poster is still paying attention, though)
Moderators: PCWjmelson
Time to create page: 0.134 seconds
