esab ultrarex retro fit plasma / flame cutter
15 Oct 2012 20:34 - 15 Oct 2012 20:34 #25348 by BigJohnT
The first thing you want to read is
linuxcnc.org/docs/html/hal/basic_hal.html
You can see in the net diagram how you can have more than one reader of a signal. So to "connect" an second reader to a signal do something like this:
something like this in your main.hal file
net my-signal thc.ark-ok <= gpio.034
in the postgui.hal file
net my-signal pyvcp.led
Last edit: 15 Oct 2012 20:34 by BigJohnT.
22 Oct 2012 15:47 #25622 by jd896
hi john still having issues with this ive gotten round the arc ok input buy linking that to the inversion of the gpio (the in_not pin)
as i had issues with the pin not exsisting and such or that the pin was already linked to another
but with the the led showing an output status i cannot do the same and cannot get it to work without error on starting axis
File Name: ESAB_ULTRA...2000.zip
File Size:5 KB
22 Oct 2012 15:56 #25624 by PCW
It would be helpful if you included the reported error here.
22 Oct 2012 16:19 - 22 Oct 2012 16:41 #25625 by BigJohnT
I get several errors:
there seems to be an error in your hostmod configuration
no tool table file
no shutdown.hal file
pid does not have a name option
your have pyvcp pin in the main hal and they are not created until the GUI is finished loading. Any reference to a pyvcp pin must be done in the postgui.hal file.
Last edit: 22 Oct 2012 16:41 by BigJohnT.
22 Oct 2012 16:46 - 22 Oct 2012 16:46 #25626 by BigJohnT
This config will run on my 5i20 machine. Note all the things I commented out and the changed hostmot config line.
File Name: ESAB_ULTRA...9603.zip
File Size:7 KB
Last edit: 22 Oct 2012 16:46 by BigJohnT.
22 Oct 2012 21:25 #25643 by jd896
thanks for all your help john i will have to look tomorrow when i can get to the shopw
22 Oct 2014 03:39 #52255 by jd896
hi again guys the machine has been running like a champ with various little tweaks here and there
one thing that i do want to change is currently i use o words to start and stop the torch ( it runs the hight control timing pierce delay and such)
and it just calls for a digi output to be turned on and waits for its arc ok on an other digi input - currently works fine
the issue ive found is that very now and then for some reason the hight control has just drifted up away form the plate (mainly due to a buildup around the sensing ring and cables - capacitive hight control)
im in the process of building a new height control axis for this machine that will be voltage controlled
for now im wanting to have it so if the arc stops for any reason the machine will pause and for some reason im thinking ive read somewhere that if i wire the arc ok signal to the spindle is at speed pin that it will pause motion if this signal is lost ?
if this is so am i right in thinking that in my o words i can swap the g64 and g65's for m5's and m3's ?
also on a side note how do i pass a variable from an on screen spin box to a o word ? as in setting pierce delay ether from software or the on screen spin box and is it possible to have the spinbox be set buy the gcode (asin if the sofeware will spit out the delay this will then change the value on screen in the spinbox and then as the program is running if the delay is too much or not enough it can be changed while the program is running ( i know this will not change the value till the next arc fire)
thanks guys
22 Oct 2014 05:41 #52259 by andypugh
I don't think so. It will wait until spindle-ar-speed is true before starting motion, but I don't think it stops motion if it goes false.
You could use motion.feed-inhibit to stop motion, or if you want a more obvious effect you could drive motion.enable false
linuxcnc.org/docs/html/man/man9/motion.9.html
The latter would take a bit of cleverness to allow motion to start in the first place, though.
Yes, and in fact you _could_ consider, with the latest LinuxCNC, making M3 and M5 into g-code subs with the "remap" feature.
linuxcnc.org/docs/html/remap/structure.html
If it is read in a G-code, then use the analogue inputs (M66). If you want it in a bash scrip then halcmd getp pyvcp.pin-name should work.
24 Oct 2014 04:23 #52341 by jd896
thanks andy as i see it on a plasma all the motion is stopped until the arc is transferred, then the pierce timer will start so would there still be a need for any cleverness ?
having thought about this some more you mean the G0 moves when the arc isn't on don't you B) i think well have to look at using an OR to connect the motion.feed-inhibit, arc ok and arc on signals somehow
also if using the spindle pins will behave no different to how u use the machine now then ill stick to my o word routines because they have saved my ass a few times and have saved me rewriting my post processor for the nesting software (i find it easier to writing subs then looking through the posts configs and saves the endless amount of walking the 50 meter walk to and from office to machine)
if i was to upgrade to the latest linuxcnc on debian will the current configs just transfer over to the new install ?
the spin box i'm after using is to set the plasma pierce delay, is it possible to have it so i can change the spin box but later down the line if i sort my material tables in my nesting software to have it tell the machine what to set this value to ?
eg could i pass a variable at the beginning of a gcode file and have the spin box update to that value
20 Jun 2017 21:23 #94742 by jd896
hi guys it been i a while with this machine and i will be the first to admit this had to be retrofitted as the controller died and once it was more or less usable it hasnt really been polished off and given it a chance to run as nice as it could do (its a shame but machines are there to be used and kind of running for how often it gets used is good enough most of the time)
anyway enough excuses
couple of things ive been using the profiler a fair bit lately and feel i can improve on the tuning one thing i have noticed is that there is still an issue of no response low down in the motion range (as in when the machine sets off hal scope looks like there isnt a response until at least x amount of volts input on the drive) is this where the deadband comes in or am i getting that wrong and if it is what im looking for how is it scaled
i think looking at the machine as it is tuned now that the amount i can change P and still have it move nicely confuses me slightly but on the other hand it looks like the ff1? (cruise error) looks to be the same or nearly the same figure regardless of P
also i have noticed that the machine doesn't respond the same ether side of zero v signal ( pnc wizard generating out put and dc meeter on servos tach showed a different speed for the same commanded signal in different directions) i set the offset too 0.025 from memory and the centered the voltage from the tach vs commanded output from linuxcnc as in 0.5 out of control showed 3.38v and -3.38v in both directions respectively i i done the right thing here ?
on a more positive note i did find some backlash in the encoder drive gear that cannot have been helping matters in the machines running so is magnitudes smoother than it was
also i have to say big thanks to any and all that has helped me along the way with this one andy jon t and pcw to name the main ones
i think the machine would thank you guys too as it possibly got save from the scrappers
Moderators: cncbasher
Time to create page: 0.082 seconds
