1982 Matsuura MC-500v Retrofit
17 Jan 2017 17:09 - 17 Jan 2017 17:10 #85958
Replied by PCW on topic 1982 Matsuura MC-500v Retrofit
I would not apply any voltage to the drive enable pins, I'm pretty sure you ground them to enable the drive
Last edit: 17 Jan 2017 17:10 by PCW.
The following user(s) said Thank You: chopper79
17 Jan 2017 17:18 - 05 Feb 2017 20:16 #85960
by chopper79
Replied by chopper79 on topic 1982 Matsuura MC-500v Retrofit
Grounded (pin1) and then applied voltage to the analog line and I can move my z axis both directions with my bench top supply.
Last edit: 05 Feb 2017 20:16 by chopper79. Reason: Removed not.... I CAN move my axis
- skunkworks
- Thank you received: 148
17 Jan 2017 17:20 #85961
by skunkworks
Replied by skunkworks on topic 1982 Matsuura MC-500v Retrofit
what do the lights on the drive indicate?
sam
sam
17 Jan 2017 17:23 - 17 Jan 2017 17:26 #85963
by chopper79
There is a green power light and then when I apply voltage to the analog +/- in the IN red led come on and the axis moves. No other lights at all.
Should there be?
Updated my reply to PCW.... I put not in there on accident. I meant to say I CAN move the axis.
Should there be?
Last edit: 17 Jan 2017 17:26 by chopper79.
- skunkworks
17 Jan 2017 17:30 #85965
by skunkworks
Oh - good - Yay!
sam
sam
17 Jan 2017 17:31 #85967
by chopper79
Now it is time to test the spindle to see i fI can get it to work and then order my mesa boards and begin the retrofit!!!!
17 Jan 2017 19:19 - 17 Jan 2017 19:23 #85981
by chopper79
Did not get the spindle moving......I need to go through all the wires and find the pins. Have the manuals so should be ok on that.
I am getting ready to order my boards from Mesa. I was planning on doing the following:
Can anybody think of why this setup will not work or anything additional I should add to the setup?
Last edit: 17 Jan 2017 19:23 by chopper79.
- Thank you received: 5912
17 Jan 2017 19:57 #85989
Replied by tommylight on topic 1982 Matsuura MC-500v Retrofit
Have a look here
forum.linuxcnc.org/30-cnc-machines/31792...rofit?start=40#85988
I did that setup since i had no constraints on budget, but it is worth every cent.
7i92/7i77 are obligatory in most cases, although 7i83 can be used for anlog outs
7i74 since i wanted to use SSI encoders on the machine ( i did order and get the incremental encoders just in case)
7i70 for inputs
7i71 for outputs ( sourcing outputs, you might need sinking ones, so do check )
You can add a 7i73 ( thank you andy ) for MPG
I like to have things separate as much as possible, and makes wiring less messy.
I am sure i will order a 7i83 and another 7i74 and a THCAD nest time i order, the versatility and support of Mesa boards is astonishing.
7i70 for inputs
17 Jan 2017 20:20 - 17 Jan 2017 20:21 #85992
by chopper79
Sounds like a nice setup tommylight
I am going to go with the 7i92M and the 7i77. I will break things out with terminal blocks to clean wiring up. On a small budget so need to keep the board count down as much as possible.
Skunkwork..... How many inputs and outputs did you end up using to get your machine working?
Keep in mind I will not be using 3 MPG like you did. I will just have a single one.
Last edit: 17 Jan 2017 20:21 by chopper79.
17 Jan 2017 21:33 - 08 Feb 2017 16:37 #86006
by chopper79
Just placed my order for my Mesa boards. I wish we had teleportation so I can have them now, as I am ready to get going on this conversion. Just a few days and I can get moving.
Last edit: 08 Feb 2017 16:37 by chopper79.
Moderators: cncbasher
Time to create page: 0.197 seconds
