Weeke BP 10
03 Feb 2017 15:16 #87215
by TSEGEO
Weeke BP 10 was created by TSEGEO
I want to retrofit my weeke bp 10 3 axis wood cnc and i need adwise.
03 Feb 2017 16:20 #87221
Replied by andypugh on topic Weeke BP 10
Servo? Stepper?
- Thank you received: 1369
03 Feb 2017 16:36 #87225
Replied by Todd Zuercher on topic Weeke BP 10
That would almost certainly be a servo machine. A Mesa 5i25+7i77 combo or something similar would probably be a good starting point. You will likely need more io as well, so additional smart serial card(s) may also be needed.
You will need to determine how much IO you are going to need, and confirm the servo/encoder interfaces, before committing to any hardware purchases.
The following user(s) said Thank You: TSEGEO
- Thank you received: 5909
03 Feb 2017 19:16 #87242
Replied by tommylight on topic Weeke BP 10
All the ones that i have seen ( newer ones ) use servo drives, quite powerfull i might add. The last one i fixed was a over 5 meters by nearly 2 meters of workspace, weighin in at over 6 tones, the whole assembly ( x and z axis) where on one side, built like a tank, it would zip that assembly at 18 meters a minute. I do not remeber the year or model, it was over 4 years ago.
Despite that, working on it was a joy as usual there is logic to everything in it ( unlike some Italian made).
05 Feb 2017 20:37 #87370
by TSEGEO
Replied by TSEGEO on topic Weeke BP 10
The maschine has Indramat karten mit num 750 control. 2,5 meter x axis 0,80 meter Y and 0,06 meter Z axis. I looking for something i can use the old indramat cards.
Maschine has 1 main spindle and 3 other spindles .I think all the they have about 11 kw. i can put some foto if it is nessesery.
05 Feb 2017 21:50 #87371
by db1981
Replied by db1981 on topic Weeke BP 10
You can use the indramats, they have -10V-10V Control.
You will need many I/Os for the relais, air relays and you will have to do
lots of PLC stuff for vacum,zylinders, spindle axis, drill transmission etc .
Whats your expirience with building machines?
I retrofited my BP10 with Ethercat and Beckhoff Components.
Where are you from?
Where are you from?
24 Feb 2023 21:35 #265281
by Steff87
Replied by Steff87 on topic Weeke BP 10
Hallo db1981,
Evlt kannst du mir bei meiner Bp15 helfen. Wie hast du die horizontalen Bohrer angesteuert?
25 Feb 2023 21:34 #265355
by db1981
Hallo,
was meinst du denn genau damit?
Die Pneumatik / Motor oder Ablauf ?
26 Feb 2023 01:33 #265377
by Steff87
Ich steh ein bisschen aufn Schlauch. Ich hab keinen Plan wie ich die Subroutine schreiben soll fir die Lochreichenbohrungen und für die horizontalen Bohrlöcher. Wie hast du das gelöst?
26 Feb 2023 09:44 - 26 Feb 2023 09:45 #265396
by db1981
Ich habe das damals alles über CAM gelöst.
In CamBam konnte man eigene Maschinen Operation als Plugin integrieren, das hatte ich dann für den ganzen Bohrkram und die Nutsäge programmiert.
Lcnc seitig waren bei mir die einzelnen Bohrer,Säge,Fräse,Horizontal alles eigene
Werkzeuge mit den entsprechenden Offset. Der Werkzeugwechsel hat dann das Ansteuern der Aggregate/Pneumatik übernommen.
Last edit: 26 Feb 2023 09:45 by db1981.
Moderators: cncbasher
Time to create page: 0.107 seconds
