Problem with Mesa 5i25
02 Jul 2017 16:12 #95281
Replied by PCW on topic Problem with Mesa 5i25
A step enable output might work marginally/intermittently if the I/O pin was not setup properly
because it will have a weak pullup if not programmed to be an output.
If you are not using a 64bit OS or one of the newer Ethernet FPGA cards,
its not really necessary to update mesaflash
02 Jul 2017 20:41 #95284
by bruno2626
Replied by bruno2626 on topic Problem with Mesa 5i25
I tried to setup and use another channel on the db25 connector for the Y axis and it doesn't work.
I setup the file .hal to use the internal connector with an adaptateur like this one:
sgcdn.startech.com/005329/media/products...arge/PEX2PECP2.B.jpg
It works fine!
It seems that several I/O pins are out of service on the db25 connector of the 5i25 board.
My linear encoder is also out of service!
It works fine!
02 Jul 2017 22:40 #95285
Are you sure the 5i25 firmware configuration matches the breakout board you are using?
You can damage 5I25 I/O pins (or parallel port pins for that matter) If you plug in or unplug the DB25 cable and a common ground does not already exist between your machine and the PC.
03 Jul 2017 08:09 #95289
by bruno2626
I used the firmware 5i25_dmmbob1x2.
You talk about static electricity? My lathe and the PC are connected to ground.
- tongqinkou
02 Apr 2018 10:42 #108253
by tongqinkou
Replied by tongqinkou on topic Problem with Mesa 5i25
I also have many problem with my stepper motor:
www.oyostepper.com/category-52-b0-CNC-Stepper-Motor-Kit.html
03 Apr 2018 13:04 #108304
Replied by andypugh on topic Problem with Mesa 5i25
Are you using a 5i25?
Could you describe some of your "many problems" ?
Moderators: cncbasher
Time to create page: 0.572 seconds
